Removing Front seats (drive and passenger)
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Jeff S., Jun 11, 2016.
  1. Jeff S.
    Jeff S. Junior Member
    17
    Michigan
    Hello everyone. I'm new to PriusCat just got the Prius this week. Very excited.
    I'm hoping someone could point towards a video or directions on removing the front seats (driver and passenger) so that I can take them out of the car and give them a very thorough cleaning. Possible with a hose on a sunny day so they dry fast.
    I couldn't find it under the search option.
    meshgearfox likes this.
  2. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
  3. MickyMatter
    260
    168
    Germany
  4. MickyMatter
    260
    168
    Germany
    Let me know, whether you need the blue linked pages or not.
  5. bisco
    52,757
    welcome, and all the best!(y)
  6. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    These 2 covers just pull off if you grab one side and kinda spread it (pull it out and up to unsnap). Just pay attention to where each cover goes. They snap back on if you hook one side and stretch it a little while pushing it down.
    Call me lazy, but I only go as far as this step here. If I have extremely dirty seats I usually remove them, spray them with something like simple green, and hit them with a pressure washer. Then I go over them with a steam cleaner to suck out as much of the water as possible and catch anything I might have missed. Make sure they have plenty of time in the sun with a fan blowing on them if needed.
  7. Charlyc
    Charlyc Junior Member
    Long Island NY
    Where can I get this manual I need to replace my OEM covers front it would be good to have
  8. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    since there are sensors and an airbag in the seats, I don't think I'd want to use a hose or pressure washer on them. if the connectors get corrosion (and it don't take much), gonna be expensive to fix.
  9. greasemonkey007
    287
    106
    True, I did mess up one sensor by getting it wet. Made sure to remove the next one. Haven't done any more yet, but they did look so much better!
  10. 69shovlhed
    2,170
    752
    Delaware
    there is a foaming upholstery cleaner the detail dept uses at the dealer. it works pretty good and only gets the seats damp.
  11. Jason in OZ
    Jason in OZ Active Member
    271
    112
    Sydney, Australia
    Bumping a slightly old thread here, but I wish to thank MickyMatter for the detailed instructions above.
    I am about to install aftermarket seat heating in my front seats.
    So the above will be very handy.
    Once we put the seats back in, will I need the blue linked pages also ?
    We aren’t changing the seats for different units, so I’m thinking any calibrations shouldn’t be needed, but I’m not sure on that.
    The extra weight from the heater kits will be negligible, a few grams at most I would think.
    Any thoughts?
    I have no idea how those extra steps at the end would be done.
    Regards
    Jason.
  12. MickyMatter
    260
    168
    Germany
    In the meantime I've uploaded the whole manual to my Google Drive. You should find it here:
    2006 PRIUS Repair Manual - 2006 PRIUS Electrical Wiring Diagram.pdf
    The blue numbers sadly aren't linked. But the PDF has a linked index. (Therefor the PDF viewer must show the PDF index instead of bookmarks or page thumbnails.) Thus at least one is able to jump between the chapters.
  13. Jason in OZ
    271
    112
    Sydney, Australia
    Thanks. Appreciate it. Will make life much easier later this week.
    I will post a thread with pics once the job is done.
    Jason.
    MickyMatter likes this.
