Removing grab handles
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Dngrsone, Aug 8, 2020.
  1. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    I am trying to run a wire from the hatchback to the front (rear dashcam), and I can't seem to be able to remove the little plastic covers to get the grab handles off (without doing too much cosmetic damage).
    How do I remove these things so I can route the wire through the headliner, and then reinstall them?
  2. Leadfoot J. McCoalroller
    7,175
    6,722
    Pennsylvania
    2018 Prius c
    Not sure if they used the same handles in your car that they put in mine, but if they are:
    Use a bit of string and ballast to hold the handle down against its return spring.
    Then look at the hinge-ends of the handle- there should be two plastic covers to pry off. Mine have little keyways to get a screwdriver or prybar started.
    Once the covers are popped off you'll find capscrew fasteners making the structural connection to the roof- back them out, catch the falling parts and (eventually) reverse for reassembly.
  3. Dngrsone
    189
    This is what mine look like. I've tried with a screwdriver in the little notches, but there does not seem to be any latches released
  4. Leadfoot J. McCoalroller
    7,175
    6,722
    Pennsylvania
    2018 Prius c
    I don't think the mechanism qualifies as a latch. Heck, it's a stretch to use the word 'mechanism.'
    AFAIK there isn't really a latch, the keyway is to let you put enough tension on the covers to cause them to deform and stretch slightly, so that they pop off of the handle hinge bases.
    More like popping a bottlecap than unlocking a deadbolt.
  5. Dngrsone
    189
    Ah, so I just need to be a little more forceful
  6. Leadfoot J. McCoalroller
    7,175
    6,722
    Pennsylvania
    2018 Prius c
    The Rules of Brute Force
    1. If it isn't working, use more.
    <end>
    Raytheeagle and Dngrsone like this.
  7. Dngrsone
    189
    Here's what they look like after removal. Prying along the diagonal seam appears to be the best bet
    krmcg likes this.
