Removing Inside Rear-view Mirror
Discussion in 'Gen 2 Prius Technical Discussion' started by ronhowell, Oct 28, 2007.
  1. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Hi All,
    I would appreciate if someone could give me some insight into removing the interior rear-view mirror in the Prius. There appear to be some screws holding the ball unit, with a plastic cover for cosmetic finish. I want to install an eyebrow window tint strip, and would find it much easier to do without having to negotiate around the mirror.
    Comments from anyone who has done this would be appreciated.
    Regards,
    Ron.
  2. mamerica
    mamerica Junior Member
    31
    Minnesota USA
    You must pop the plastic cover off the base. There is a tab on each side that attaches it to the base It is best to use something made from plastic to pry it off. Once you pull that part down, there is a tab that you press and slide the mirror up and off of the mount.
  3. ronhowell
    681
    32
    Cypress, CA.
    <div class='quotetop'>QUOTE(OutOfHere @ Oct 28 2007, 07:41 PM) [snapback]531764[/snapback]</div>
    Thanks for the input. My email is [email protected]. Would appreciate copies of the pix you mentioned.
    Cheers. Ron.
  4. blamy
    blamy Member
    380
    Central Florida
    You will need a T-15 screwdriver and it comes right off. You can get the screwdriver at Sears / Home Depot or Lowes
  5. blamy
    blamy Member
    380
    Central Florida
    <div class='quotetop'>QUOTE(BuddyL @ Oct 29 2007, 05:51 PM) [snapback]532123[/snapback]</div>
    Sorry I had replacced my mirror with a auto dimming model and then replaced it with an auto dimming with compass and forgot the original did not have the T-15 torx screw but had the little plastic thing that Outofhere describes. My apologies.
  6. ronhowell
    681
    32
    Cypress, CA.
    Thanks to all.
    Solved the problem. The mirror simply slides off by pulling upwards to the rear. A spring loaded clip clamps the whole mirror assembly to a grooved attachment built into the windshield. Very simple, no tools required. Knowing how it is attached is key.
    Ron.
    OBJUAN and Sezy like this.
  7. charlievet
    charlievet Junior Member
    Naples, FL
    Thanks Ron! Your method works perfectly well for the Prius III, as it has a spring-clip, too!
    Charlie:)
  8. Sezy
    Sezy Active Member
    427
    225
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Going to try this and take the mirror apart further to help with rattles from my subwoofers.(y)
