Removing spare tire and tools to reduce weight.
Discussion in 'Prius c Accessories and Modifications' started by Daniel Grevillius, Mar 20, 2014.
  1. Daniel Grevillius
    Daniel Grevillius New Member
    Newport News, VA
    So before my Prius C, I had a 2012 Elantra and those do not come with a spare. When I bought the car, I was told Hyundai did that to reduce weight. In its place, they give you a portable air compressor pump and a canister of tire sealant to patch holes.
    Continuing with this idea when I got the Prius, I bought a kit off Amazon and removed the spare tire.
    This is it:
    Has anyone else done this?
  2. priusCpilot
    priusCpilot Active Member
    631
    209
    LA
    A Warning to you. The spare tire also is part of rear impact protection.
    Your crush zone will increase without it.
    I would love a lighter aluminum or magnesium option.
    citroenjohn likes this.
  3. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    Thanks PriusCpilot. I never would have considered that the spare tire is part of the rear impact protection. It makes sense though, learn something new everyday. Thanks again.
    49,371
    what did hyundai do to improve the crumple zone without a tyre? beef it up resulting in more weight?
  5. JGriffin
    JGriffin Junior Member
    16
    Little Rock, AR
    Personally, I think I would avoid using a slime sealer on a punctured tire and would prefer an actual puncture repair kit. The slime might mess up the balance of the wheel. If this is totally off-base, someone please correct me. Plenty of people have removed it though, many for the purpose of installing a box for a subwoofer.
  6. Boberic
    Boberic Junior Member
    17
    It really doesn't matter if it messes up the balance as anything liquid you put into the tire is not going to seal it permanently anyway. Plugs work better but are hard to do when the wheel is mounted on the car and it's cold, dark, and rainy and you can't find the hole you're trying to plug.
    It is true that you may have to clean the inside out when the tire is plugged, though, but I wouldn't think that would be much more involved than wiping everything down with a rag after you break the bead (so you can get your hand and rag onto the inside surfaces.)
    JGriffin likes this.
  7. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    My wife has a saturn vue hybrid and it has the fixaflat can and compressor. Both of which are worthless.
    one day while driving to work she got a puncture in the sidewall. she was about 1/2 mile form work so she drove to work. Thankfully I have ebnough freedom and only work about 5 miles away. i was able to tak emy HHR(before the prius) and use that jack to raise her car so I could get the wheel off and bring i tbakc to my work and put a new new tire and a new TPMS (which alos got hit by the puncture) and I had to buff out a few gouges of the rim as well.
    So with out a spare tire, and with out a loving husband, it would have cost us probably minimum of a hunded bucks to get to towed to my work, and probably worse if I had to get towed to a shop, not many auto repair shops in down town DC. One tow job woudl have been more expensive than the jack/tire.
    With the Vue Hybrid it was a weight saving measure as non hybrid versions have a spare and jack. inplace of the spare tire it has a big foam block with cutouts for the compressor and fixaflat can and a few other kicknack cubby's.
    I think on many cars now a spare tire is an option...
    I should probably put a spare and a jack in the saturn...since its our family car...
  8. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    No because..............
    The fuel savings from doing so are so tiny that you might save a dollar over ten years or so.
    AND....not all tire failures are fixable with "goo".
    It's a personal decision.
  9. Mendel Leisk
    38,644
    The grass is always greener on the other side I guess. While you're pulling out your spare, plug-in owners are pulling out their hair: buying spares or extra full size, and cobbling together methods to secure/transport them.
    Keep in mind one screw or nail is going to mean a slime filled tire for you, while your spare sits at home.
  10. Mike500
    Mike500 Senior Member
    2,593
    764
    I really don't care about a mileage hit.
    Over the past 40 years or more, I've been in situations where I had two flat tires on one side.
    I carry both the "donut" spare and a full size spare.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Auto manufacturers and Car Salesmen are going to promote the absence of a spare tire by trying to sell you on the "less weight" better gas mileage aspect.
    I don't really buy that.
    The weight of a spare is so minimal, unless you are carrying around a full sized hydraulic jack, I don't see the "savings" as being an issue. My guess is that for auto manufacturers the real reason is primarily cost. Probably cheaper to simply give you sealant and a compressor.
    The "better" argument might be safety. A surprising number of people get injured or killed every year trying to change a flat tire.
    Also I think a lot of the younger generation is just less adept at mechanical things like changing a flat. Most people never practice doing it, it's a bit less intimidating and easier to spray in some goo and then it either works or you call for a tow.
    I feel better with a real spare. I also am perhaps self delusional and confident that in most cases I could get the spare installed without injury or worse. Been a long time since I've had a flat...but I use to be able to change a flat tire.
    But I think with Cell Phones, Road Side Assistance, and greater profit margins and less risk...to both user and manufacturer, puncture sealants "systems" instead of spares...are probably the wave of the future. I'd be surprised if that doesn't become the norm for more and more vehicles.
  12. Mike500
    2,593
    764
    I carry around the 23 pound $60 (with coupon) Harbor Freight aluminum racing jack.
    I was once in a really bad neighborhood one night. I got a flat, put the aluminum cheater pipe on the lug nut jack handle and loosened the lug nuts, whipped out the jack, took off the tire, put on the spare, lowered the jack, tightened the lug nuts, and I was gone in 15 minutes.
    A lot of those who get a flat tire are robbed both literally and figuratively by others on the highway.
    Mr Incredible likes this.
  13. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I believe it would be a false economy to remove the spare. There isn't enough weight savings in the first place, and paying attention to your driving would more than overcome the small amount of weight.
    I recall assisting a a rather nicely dressed female with a flat tire as I was leaving work last summer. She had out the compressor and fix-a-flat that came with her car. The only problem was that the hole in her tire was on the sidewall. It was really sad to see the white liquid drooling out of the sidewall hole. Good thing she had AAA on the phone when I got there.
    A big part of life is putting yourself in a position to come out of negative situations on the positive side. I don't see your plan as assisting that quest.
    Good luck.
    Mike500 likes this.
  14. Mr Incredible
    955
    506
    Neb
    I also carry a 36oz .45 to assist when required.
  15. Mike500
    2,593
    764
    I carry a 15 inch of half inch nominal aluminum pipe to go over the prying end of the OEM lug nut wrench, since the lug nuts might be over tightened. The pipe weighs no more than 11 ounces.
    I put a grip handle on the end, so that makes it a dual use tool, when it comes to "taking car of business."
    In remote locations, where there is NO cell service like the farmlands of Nebraska and Iowa, I can see how a .45 inch Automatic Colt Pistol can help.
  16. Mr Incredible
    955
    506
    Neb
    You just never know when a rabid possum will jump out of the ditch and require some remedial education...
    I have a 3 d-cell maglight for the smaller possums. There are many brighter flashlights, but it has a nice heft to it...and lots of reflect-o tape.
  17. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    To put it in perspective, cruising at 40mph a reduction of 20lbs reduces the required hp to maintain speed by ~0.45%. So if you drive 10,000 miles per year at 50mpg using 200 gallons you might save 1 gallon per year.
    The savings is further reduced at higher speeds, as the wind resistance becomes dominant. At 70mpg the savings is about 0.27%.
  18. Mike500
    2,593
    764
    However, peace of mind is priceless. I'd keep the spare.
  19. fourenty
    fourenty Junior Member
    46
    25
    Endwell, NY (near Binghamton)
    Where did you read this? Hard to believe that anything that may be removed from the car is part of the engineered rear impact protection.
