removing sticky sticker residue from windows
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hoodenc, Apr 3, 2008.
  1. hoodenc
    hoodenc Junior Member
    17
    Hello,
    Anyone have any tips on removing sticker residue from the inside of the windows and windshield? I figure rubbing alcohol will be fine, but just wanted to see if anyone else had any remedies.
    Thanks!
  2. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
  3. SparrowHawk60
    SparrowHawk60 Happy to be green!
    411
    Town of Newburgh, NY, U.S.of A.
    Bug and Tar remover.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Eucalyptus oil. Magic stuff and it clears your sinuses.
  5. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Start with a razorblade to remove as much of the sticker as possible so there is less residue.
  6. lesturner
    lesturner Taming the Dragon - Tennessee
    75
    Bremen, IN, USA
    Medical Adhesive Remover.... Available at most medical supplies, doctors offices, and hospitals...
    This stuff really gets it off easily. I have used it to remove the DNR stickers from boats that have been in place for over 10 years...
    It is not expensive.
  7. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    I have used Goo Gone for years and it works great; and it's widely available at hardware stores, drug stores, etc. But it's petroleum based, and like a lot of other commercial solvents, it has a pretty strong chemical smell. So that medical adhesive remover that Lesturner mentioned sounds great too (cheap, effective, odorless, non-allergic), as does the eucalytus oil Pat Sparks mentioned (fairly cheap, effective, smells good, clears sinuses).
  8. MaulWalker
    MaulWalker New Member
    23
    Marietta GA USA
    Fingernail polish remover (with acetone) will do it too.
    Lynn
  9. TeamWenz
    TeamWenz New Member
    34
    Madison, WI
    Lighter Fluid does the trick every time.
  10. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    Goof-Off works great. I took off all of the stickers on my car using it. I would imagine nail polish remover would also work well. I would shy away from using anything sharp, such as razor blades and the like. You don't need them when using Goof-Off. The stickers come off with little effort.
  11. Jack66
    766
    Stafford, Virginia
    Keep the lighter fluid and nail-polish remover away from your paint.
  12. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    Starting fluid (ether)
  13. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    I used "Invisible Glass" spray and a diaper. It came right off.
