Removing Tail Lights
Discussion in 'Prius c Technical Discussion' started by theperfectexposure, Nov 25, 2013.
  1. theperfectexposure
    theperfectexposure New Member
    Hi everyone, I have been trying to remove the tail lights to install LEDs. Are there more bolts than just the two bolds on the outside? Please advise
  2. Mr Gee
    Mr Gee Member
    88
    30
    Australia
    the two bolts are all there are. after that just prise each corner rearward slowly. they will eventually 'pop' out
    Changed my reverse lights to cree 5 leds
    MNBud likes this.
  3. AliIzad
    AliIzad Member
    170
    72
    Southern California
    I have removed mine several times. Remove the two bolts, grab the taillight with both hands, and firmly pull straight back towards yourself. It will feel like it doesn't want to let go, but it will. Make sure you put down a towel or something soft, because if you don't completely unplug all the bulbs, it will hang down onto the bumper and possibly the side of the car. Putting it back on; make sure you line up the small slots on the outside edge of the lights, and the the small pins will pop right back in. And don't over tighten the bolts, just snug them down. The owners manual also shows you how to do it.
    mertechperformance and MNBud like this.
  4. MNBud
    MNBud Junior Member
    48
    suberb of Minneapolis MN.
    Thank you guys,I was just nervous that I would break something more than I already had. After your replies,I removed it and now feel secure that I will be able to replace the lens and save $117.00 that the dealer wanted to replace this.I may need to picture the wire routing, but that won't be an issue.
    mertechperformance likes this.
  5. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    Yup, nice and easy, get to savin' some dollas!
