Removing the Dash
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cooper_s_1275, Mar 8, 2011.
  1. cooper_s_1275
    cooper_s_1275 Prius Newbie
    Hong Kong
    Hi all,
    may I ask if anyone could tell me how to remove the dash of my GenIII?? I'd like to install Ipod Cable under the CD player...
    Many thanks!!
    Clement
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Click on the Pioneer HU link in my signature.
  3. cooper_s_1275
    Hong Kong
    Thanks a lot mate, actually I've found that link and that PDF is much helpful... but it's just that I cannot feel the click while i try to take it off, so I havent actaully got it done yet. may I ask if you would be able to describe a bit more on how to do remove the first piece? will you be able to post one or two photos on where exactly the place i should pull on??
    sorry for the hassle....
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    No problem... totally understand the fear factor. :eek:
    On either side of the shifter about 1" down from the top surface you will feel a seam. Put your fingertips/nails in the seam at point labeled 1 in the attached picture and give a good firm lift up. Once the tabs release, do the same to the black piece around the shifter itself and remove. The rest is history.
    Good luck!
    kc410, king mob and cooper_s_1275 like this.
  5. cooper_s_1275
    Hong Kong
    Cheers mate, I had suspect on those little gap on first hand, now I'd have confidence to do that. Thanks a lot. I will install my Iphone interface soon...
