Removing the rubber section in wheel well?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by aridon99, Jan 5, 2006.
  1. aridon99
    aridon99 New Member
    67
    San Mateo, CA
    Hi folks. I purchased a one day subscription last week to the Toyota techinfo site looking for documentation on how to disassemble the rubber section inside the front wheel well. I need to remove this part to get to the raw metal so I can slap on some dynamat deadener.
    Thank you in advance for any feedback you can give me.
    -John
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Did you find the manual sections about removing the wheel well liner? What will sound deadener do for you outside the cabin?
  3. aridon99
    aridon99 New Member
    67
    San Mateo, CA
    Bill, I couldn't find the section that has to do with removing parts on the outside of the car. If you can point me to the right section, I would be grateful.
    Putting deadener on the outside to try and put a barrier between the source of noise (wheel hitting road) and the inside. It's like wearing a Kevlar vest on the outside, to protect the parts inside ;)
  4. tochatihu
    tochatihu Senior Member
    9,059
    3,529
    Kunming Yunnan China
    2001 Prius
    My complaint with the wheel wells (2001 Prius) was always that gravel sand etc. that is lifted by the tires makes a lot of noise there. Quieting the wheel wells would make a big difference sometimes.
  5. Lather
    Lather New Member
    27
    I don’t know if I would put dynamat in the exterior wheelwells. I'd be worried about extreme temperatures or high pressure sprayers. Plus, with large concave surfaces, you're more likely to get air bubbles.
    I used dampening paint & dynamat on the interior of my car. (Floor, wheelwells, doors - any bare metal I could find). The only road noise I hear comes from the tires and/or the thin metal & plastic pieces under the car & ww’s when it snows or rains (I don’t drive gravel roads). I’ve got a few cans of undercoating but haven’t had time to apply it. When I do, I’m not going to remove anything, just deaden the pieces that make noise.
    When I undercoated my last vehicle, the undercoating seemed similar to the sound dampening paint. Except for the price, I didn’t have to spend $60/gallon.
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I just installed the front end mask. It requires you to remove the edge of the liner and replace one of the fasteners with a snap that you snap the edge of the mask on to. The fasteners are 2 part clips pry the center portion out with a screwdriver. There is a slot between the two parts. When the inner portion is out the outer clip just pulls out. The liner then just comes out with a bit of pulling. That is the outer edge. I am not sure about the inner edge as I did not have to mess with that edge. Look at it. It might well be the same.
