Removing trunk side cover / panel
Discussion in 'Gen 4 Prius Main Forum' started by Bristolbob, Mar 25, 2023.
  1. Bristolbob
    Bristolbob New Member
    UK
    Does anyone know how to remove the trunk side moulding cover (highlighted) so I can check behind it? Have removed 2 bolts but the upper part of the moulding is held in place by the plastic panel above it. Water pours through the gap by the rear tailights and into this area then down to the trunk and rear seating.
  2. Elektroingenieur
    2,515
    3,287
    Three Touring
    The Repair Manual (more info) explains, in the procedure for removing the roof headlining, how to remove the deck trim side panel assembly LH and RH. If you’re looking for a source available at no cost, see steps 6–14 (pages 11–17) of the Towbar Wiring Kit 13-pin Installation Instructions (PDF); the symbols are explained in a separate document (PDF).
    UN4GTBL, CA Guy and Bristolbob like this.
  3. Bristolbob
    UK
    Thank you! That looks ideal - will give it a go
    Elektroingenieur likes this.
  4. CA Guy
    CA Guy Junior Member
    24
    Three Touring
    Toyota instructions are absolutely work of art. It is so enjoyable to read.
  5. Purrius
    Purrius Member
    167
    49
    Northeastern US
    (Hope it's okay to revive this thread:))
    Did you solve the leaking problem, OP?
  6. Mendel Leisk
    41,894
    Clicking on his avatar, last post he did was march 25, 2023, so maybe.
  7. Purrius
    Purrius Member
    167
    49
    Northeastern US
    Aw, well heck.:oops:
  8. Noshame
    Noshame Junior Member
    Washington
    What questions did you have?. I am trampling the dame problem right now. I have so if the panels removed on each side in the rear abd dm do having questions as to where exactly the water may be coming from? I think I can tell but I don't want to be going back through this anytime soon. I guess I'll just have to do the'ol fix one Crack and or water after to confirm the isn't anymore coming through before moving to the next area. FML
