repair advice needed for Prius caught in a flash flood
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mentavlos, Aug 4, 2011.
  1. mentavlos
    mentavlos Junior Member
    Minneapolis
    Hi everybody - I have a 2010 Prius IV that was in a parking lot that was flooded during a heavy rainstorm. The water rose up about an inch higher than you see in this photo. Everyone else was able to throw their cars in neutral and push them to higher ground, but mine sat in this water for a little more than an hour.
    The dealership hasn't completed its analysis, but they were able to jump-start it and there wasn't a flood (get it?) of error lights, so their list of things is shorter than you'd think. Mostly interior revamp, since the water did rise up about 2 inches into the seats. The service guy had initially told me that when he saw water at this level, the adjustor would typically total it out due to all the unknowns, but my adjustor asked for the teardown and analysis, so here I am.
    I'd like to consider myself lucky, but my fear about going the repair route is that there must be a lot of electronics that was underwater that won't start corroding until after insurance has wiped their hands of it. Do any of you have any recommendations for systems that you just know must have been underwater, for which I should push for replacement now?
  2. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    I'd think any computers or black boxes that were submerged as a start
  3. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Modern Electronics can be relatively tolerant to moisture or even flooding, you haven't really said anything about codes, start-up problems. Are you a DIY? :confused:
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Have the transaxle fluid drained and checked for moisture, maybe send out a sample for analysis.
  5. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Agreed. Be sure to have your service change the transaxle fluid AND the 1.8L engine oil (0W20).
  6. mentavlos
    Minneapolis
    That's good to hear about the electronics. I'm not a DIY. The car is at a dealership but I haven't heard their final report. It wouldn't start, but it would once they jumped it. Apparently it wouldn't turn off naturally, so they're still looking into that. They didn't get any codes, so that's bodes well in a way, but my fear is that there are some enclosed pieces that aren't going to get insepected unless they throw a code, and that if they got wet that there will eventually be corrosion-related issues that won't turn up for a while.
    So I guess what I was wondering is whether there is some consensus about which computers/electronics are below that water line that would ideally be replaced in a more proactive way, if you know what I mean.
  7. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Not turning off on a Prius that has to be jump started is a symptom of a dead cell(s) in the 12V battery.
    Most of the computers are at the level of the bottom of the glovebox or higher. There may be sensors that were compromised, though, like yaw rate, which, if memory serves, is mounted to the floor pan.
  8. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    My thoughts are that you may want to look into a new insurance company.
  9. andyprius
    2,212
    188
    Should you decide to DIY, you should access every connector at or below the waterline, spray with electronic cleaner spray, shake off excess ( if possible ) touch up with a hair dryer, moderate heat. There also may be something on the market that prevents future corrosion on connectors. Then, reseat the connectors 1 or 2 times. All this being to (help) insure future good conductivity. The best arrangement being an equitable settlement from the Insurance company AND keeping the old car. Your Prius sounds pretty good tho! Again in regards to your Prius, if offered a good settlement, take it and buy a new one. Contrary advice, but one never knows when water damage might show up. In regard to the above maintenance, this is something that the dealer should do but probably will not.
  10. andyprius
    2,212
    188
    "My fear is" You are absolutely correct!
  11. mentavlos
    Minneapolis
    I thought that myself when the adjustor asked me, "Now, is that a hybrid?"
  12. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    How about the traction battery? Was any part splashed or submerged?
  13. mentavlos
    Minneapolis
    I was told there was no evidence of water there. But because insurance wanted to take photos before anything was ripped apart, there was a good 40 hour delay before anything was looked at. What's that compartment like? Could it have drained away and dried up in that amount of time?
  14. paprius4030
    paprius4030 My first Prius
    2,077
    295
    Ormond Beach,Fl.
    Since it wouldn't start, obviously something got wet. I'd demand they total and get you a new Prius. Maybe you should start looking for a good lawyer.
  15. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    I personally wouldn't accept that car back. Get the insurance to "total" it. Or else, you have the potential to run into issues down the road. Big time.
  16. jim256
    jim256 Member
    317
    69
    Eastern NC
    And, if you ever plan to sell or trade the car, the water level will be pretty obvious later on when rust is prevalent on the seat rails, sills---anywhere that the water lingered.
  17. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    There are cables and wires under the car and, as previously mentioned, some of them have connectors that got wet. Each wheel has a speed sensor for the ABS/VHS systems they certainly got soaked. Brakes will be rusty and should be looked at. I also recommend changing brake fluid.
    One big problem is they will overlook things, and there will be other things that will not be done thoroughly enough. Some of these things will probably fail down the road and the insurance company will not cover them at a later date.
    If it were mine I would try to get them to total it. If you can't do that sell it to someone you don't like. :)
  18. mentavlos
    Minneapolis
    So the dealership estimate ended up at $14k, which is not enough for insurance to easily make the decision to total it (apparently that threshold is 70%), but I think I'm now in the territory where I can press my case for that outcome. Thanks to everyone for all of the tips on what to look for.
  19. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Any chance you could post the details? Inquiring minds are curious.
    Push hard on your insurance co. They might actually come out ahead if they total the car, since 2010s with straight body and intact air bags fetch very high prices at insurance auto auctions.
  20. mentavlos
    Minneapolis
    I got a new adjustor assigned to the case and his inclination was to total it and I heartily agreed. I think you're right about what they'll get for it at auction. The settlement offer was very fair, thanks to the amazing resale value of the 2010 IV w/solar package. It was actually worth more today than what I paid for it last September.
    The biggest ticket item on the repair list was, of course, labor. After that came the stereo and the wiring for the instrument panel. There was some other wiring in the floor that they were going to replace, too, and those harness assemblies were $500+ and $700+.
    Of course, getting more than what I paid for it last September doesn't exactly help me land a new IV w/ solar package without paying quite a bit more and waiting longer than I am able to wait. Sad, because I really loved the Prius, but I think I'll now have to wait to rejoin the fold until our 97 Subaru bites the dust (why of why, couldn't I have driven it on Monday?!?) and hopefully then supply will be back and I'll get the smoking new plug-in version.
    Again, thanks to everyone for all the support and advice.
