Repair oddities
Discussion in 'Gen 3 Prius Main Forum' started by KB9MNM, Dec 4, 2022.
  1. KB9MNM
    KB9MNM Junior Member
    Oswego, IL
    Hi everyone, happy holidays!
    2014 Prius, Mrs swerved to miss a stopped car, hit the median curb, blew tire and jazzed up the left front wheel. Got it back from the body shop and couple of odd things I’ve noticed:
    climate control starts cranking out hot air at 70. TPMS light flashes several times then stays on.
    Shop said there were a couple of warning lights on that needed to be diagnosed.
    I’ve tried to reset the TPMS light but read it may be an actual issue with a sensor(left front obviously).
    Can the climate control system be reset?
  2. JC91006
    16,474
    8,393
    The TPMS sensor is an easy replacement, just replace and reprogram the new one into the car.
    The climate control should have no relation to hitting a curb. Maybe take it off "Auto" Setting
  3. ASRDogman
    ASRDogman Senior Member
    6,044
    3,245
    Is it Ground Hog day againi already?
    You should take it back to the repair shop and tell them to fix you car.
