Repair or engine swap
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ducatiduke, Jan 11, 2021.
  1. ducatiduke
    ducatiduke Junior Member
    31
    NYC
    I have 2010 Prius with 195k miles on it. It is a good car with a good body and good interior so I would like to keep it. With the pandemic, it has not been driven for some time. I went to start it up and it presented the engine knock at start up. In addition, I believe the previous owner I suspect was not the best at maintenance because it consumes a fair amount of oil ~ 1 quart every 1000 miles. The other reason I do not think it was not taken care of is they did not have any maintenance info.
    Questions >
    1) Would it just be easier to just swap the motor out with one of those used 50K motors that are being imported from Japan? If so, how much should I expect?
    2) Or should I just take it to the dealership and have them tell me what they think?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I would drive til it won't then swap with lower mileage motor
  3. ChapmanF
    18,530
    The dealership will think you should make them rich, that's what they'll think.
    I think I'm with tankyuong, when the time comes it can be replaced with a lower-mileage one, whether from Japan or from a US wreck, but just using some oil and occasionally making the start-up noise doesn't necessarily mean the time has come yet.
    Some members will reply on any thread about the start-up noise by saying the head gasket must be blown (and will often say further that it must be because of the EGR), but my 2001 made that same startup noise occasionally for its last few years. I never found out what it was, but there wasn't any head gasket leakage happening, and a 2001 has no EGR.
    If you wanted to do a leakdown test and/or check the condition of the EGR circuit, nobody would call you crazy. It might give you some idea how soon the time might come, or reassure you that it's not right around the corner.
    tvpierce likes this.
  4. Mendel Leisk
    41,889
    If I may...?
    How’s the engine coolant level in the reservoir? Stable?
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,490
    6,576
    Texas Hill Country
    Time to pull this out again:
    Mr. 2010-14 Prius
    Knock Knock Who's There?
    Stage 1
    Spark Plug and Coil Change
    Clean EGR
    Monitor Coolant
    Try Head Gasket Sealant
    Stage 2
    Order a Motor from Japan
    Arrange Killer Install Deal
    Stage 3
    Question Motor from Japan
    Stage 4
    Decide to Change the Head Gasket
    Stage 5
    Reconsider Motor if yours might have a Bent Rod
  6. ducatiduke
    31
    NYC
    #6 ducatiduke, Jan 11, 2021
  7. ducatiduke
    31
    NYC
    @ChapmanF Thx for you comment. I will look into doing a leakdown test and/or check the condition of the EGR circuit,
  8. ducatiduke
    31
    NYC
    @ Mendel Leisk
    Thanks for your comment! I just looked and it is right in the middle of the F and L lines. I do not know if it is consuming but it appears to be ok at this point. I know at one point I added some but I think it was years ago
  9. Mendel Leisk
    41,889
    Put a strip of masking tape vertically, mark current level (cold) with a sharpie, and keep an eye on it. Sounds ok, but good to verify.
  10. ChapmanF
    18,530
    Whatever causes it (and various things can), it makes a very unnerving loud clatter; speed variations of the misfiring engine get compounded by drive train clatter in the gearbox, as described on page 4 of this article.
    Anything that might cause a startup misfire can cause it. The article above is interesting because it gives a good example of a methodical diagnosis, and in that case it all came down to one bad spark plug. But the sound was so awful the owner had already let the car go for scrap price before that could be diagnosed.
    The TSB linked in #6 above has more to do with cases where Toyota apparently thought the cause was condensed water in the EGR passages being slurped into the cylinders right upon starting. Water does condense in those passages; I've never been quite sure how it gets slurped on startup, given the EGR valve should be closed then, but perhaps if it is fouled and not completely closing, enough airflow through the pipe can be developed to carry the water out. Toyota released a redesigned manifold with the EGR passages routed differently, but it didn't turn out to be a silver bullet.
    Naturally, EGR as a cause is only possible for Prii that have EGR (2010 and later). Other causes (like the spark plug in the article) are possible in any Prius generation. As I mentioned earlier, I never did find the cause in my old 2001.
    And yes, a faulty head gasket can cause misfiring, so it is also a candidate for the cause.
  11. ducatiduke
    31
    NYC
    @tankyuong Thanks for your comment! I am all for that... I am just trying to avoid getting stranded somewhere... But I do tend to agree...
  12. rjparker
    10,490
    6,576
    Texas Hill Country
    Normally a plug or coil that is the root cause of the misfire won't clear up so nicely after a few seconds. Plenty of head gaskets start out using minimal antifreeze. A dealer will normally recommend changing the engine for $5k up. Some report changing engines for $2k-$4k using independents, head gaskets alone from $1k-$3k. Obviously losing antifreeze and white smoke are late stage head gaskets symptoms.
  13. ducatiduke
    31
    NYC
    @rjparker Thanks for your comment! Looks like I am going to start working on Stage 1... Are you saying I could have a bad coil without pulling an check engine light? The reason I say this is I had a VW Passat that pulled many codes when the coils were acting up.
  14. Mendel Leisk
    41,889
    You’ll see P03XX for misfire, with XX being 01 through 04, corresponding with cylinder numbers. Standing in front of engine compartment, cylinder 1 is at left end, aka the “front” end of engine.
  15. rjparker
    10,490
    6,576
    Texas Hill Country
    An intermittent misfire won't always throw a code, especially if it clears quickly and the engine runs good for the rest of that trip. If it was a traditional plug or coil fail then a code would be expected. Many have been where you are and have found completely blocked egr coolers, a bad design on gen3s as are the pistons and piston rings, at least from 2010-14. The egr system was redesigned in gen4 engines and better piston rings were in place by 2015.
    There is quite a debate on the root cause of head gasket failures with these engines including theories like blocked egrs, oil burning, high speed driving, thermal cycling during the drive cycle, oil pooling in the intake, head gasket materials, head gasket geometry, pinging caused by carbon buildup and most recently, a dealer mechanic who thinks it is chronic overfilling of the oil. Usually its high mileage engines that are arguably worn out anyway. Some buy time with head gasket sealants.
    Getting an accurate diagnosis should be the first order of business.
    Ed Beaty likes this.
  16. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Definately don't assume it's a blown head gasket. My '13 had an intermittent knock on cold start -- mostly upon first start in the morning with cold winter ambient temperatures, but not every morning. It started around 100K miles. I now have almost 180K miles. I've installed an oil catch can, and cleaned the the EGR twice -- once at 115K and once at 172K -- both times the cooler and intake manifold passages were completely plugged allowing 0% flow. I can't say definatively that either of these maintenance items directly solved the knocking problem because both times the EGR service was done in the spring, when the knocking had already ceased due to seasonal weather change.
    But this winter the knocking has not returned at all -- not once. My assessment is that there's no way the head gasket was leaking at 100K, and now at 180K it's miraculously fixed itself.
    I guess that's just a long way of saying, we all know the knocking comes from a misfire. And while a leaking head gasket certainly can cause a misfire, not all misfires are caused by a leaking head gasket.
  17. ChapmanF
    18,530
    THIS.
    Paul E. Highway likes this.
  18. Mendel Leisk
    41,889
    A leak-down test will help.
  19. rjparker
    10,490
    6,576
    Texas Hill Country
    Another head gasket data point, dealer mechanic's livestream from a couple of days ago acknowledges the rate of gen3 head gasket failures is "alarming" and they don't know why. Realize most dealers recommend replacing the engine which effectively junks these cars.
    The question being answered asked if Toyota changed something in 2012 and the mechanic ran with that, but we know the rings and pistons changed by 2015.
    Interestingly, the mechanic says the engine parts are rarely warped, suggesting overheating is not the prime suspect.
  20. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Interesting!
