repair service I smell a rat
Discussion in 'Gen 2 Prius Main Forum' started by hmbprius, Dec 2, 2005.
  1. hmbprius
    hmbprius New Member
    My parents (who I convinced after I got my Prius) got their Prius this summer. Recently it had the emergency 'see dealer immediately' light come on. I thought it may be the computer programing issue (my car is currently getting that tweaked) but it turned out to be a problem with the water pump.
    Now here is where the rat comes in. Literally. The repair folks claim (although they provided no physical evidence) that there were rodents chewing the wire and that led to the pump failure. Despite my parent's platinum warrantee (thanks Prius chat and Greenfield Toyota) they are getting charged diagnostic fees, and $310 for the pump .
    I smell a rat...and it wasn't I am sure in my parents car! (it isn't lilke they park in a field or anything!).
    Help!
  2. 2Hybrids
    2Hybrids New Member
    565
    Eustis, Florida
    They (service) have to provide damaged/repaired/replaced parts for inspection upon request. Did they ask to see this chewed wire?
  3. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    I agree. PROVE IT!
    At this point, even if they produce chewed wires, can they prove that the wires came from your parents' car? I would fight this one.
    Pick up the phone and dial this number:
    "Customer Experience Service Line" : (800) 331-4331 x33
    When I had a problem with my stereo, I called and they saw me through the entire thing. Very nice, extremely curteous.
    $310 is a good sum of money especially since the warranty was purchased. Call them.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    And wouldn't "chewed wires" just cause the water pump to quit? How would that cause physical damage to the pump? Seems it would be as simple as fixing the chewed wires and the pump should work as good as new. (note: I claim ignorance here as I suppose it's possible that by shutting off while the car is running damage might occur to the pump for all I know)
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Man i would tell them to "Just fix the wire". I'd even have it towed to another Toyota dealer. I think any decent dealer would honor the warranty even if this really was the cause. On the warranty claim form all they have to say is"fixed broken wire".
  6. mehrenst
    mehrenst Member
    439
    San Jose, CA
    :huh:
    California State law REQUIRES that all replaced parts be given to the owner/person paying the bill. I couldn't even just tell the guy that was doing service on my Bronco-II to just throw them away. He insisted that I carry them out the door (if they were small enough). :unsure:
  7. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    i agree. anyone who refuses to give replaced parts, that weren't covered under warranty, to the owner of the car is breaking the law in most (if not all) states.
    [just for your info, everyone, toyota takes back all parts that are replaced under warranty and sends them back to the factory to be analyzed for their information.]
    it's also bad business practice in general.
    i also don't know offhand about whether a certain wire could be chewed and short the pump motor or something. maybe i'll be able to get an answer to that if someone else doesn't beat me to it.
  8. onerpm
    onerpm New Member
    477
    MN
    you should tell your parents not to eat in the car
  9. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Hard to see how rats chewing a wire could burn out a pump. I'd expect just a fuse to blow.
    But I do worry about rats and mice! They got into my central AC at my house and chewed up enough wires to blow the breaker. I have not rewired it yet to see if anything got damaged beyond the wires, but I would expect it to run fine once I put in new wiring.
  10. galaxee
    9,810
    465
    MD
    here's what i was told.
    most likely, the pump is fine and will run again once wiring is repaired. if they insist, you go get a second opinion before replacing it. or just ask them to repair the wiring first and leave the pump. if the pump is still nonoperational (which you should go ahead and confirm) then allow them to replace it. they should not do any work without your approval; however, it isn't mandated by law in all states that they wait to hear from you before doing the work up to a certain dollar amount. so if you don't trust them, put it in writing.
    under a chance circumstance, such as the wire was broken and was still able to intermittently touch, the voltage spikes caused by that intermittent touching could have damaged the pump. but that is highly unlikely.
    good luck.
  11. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    It is in California. I don't know if his parents live in the same state he does, though.
  12. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Who I don't know but this appears to be over the top. You need the parts and then have a independent observer look at them.
  13. Rick Suddes
    Rick Suddes Junior Member
    Chewing Rat problems
    PHP:
    [I see there is a big problem with ratsmicesquirrels raccoons chewing up
    wiring
    hoses in cars in carstrucksmotor homes homes etccheck this product out at [URL]http://www.Rataway.com[/URL] it works well it has been proven and tested for well over 5 plus years.[php]
    I understand the rats like the Pilot car from Honda Motors to chew onI have heard that they use soybeen product in the wiring hoses in some cars and the rats love itWhat does anyone know about this
    Also plumbers are installing plastic water lines red for hot blue for cold.
    A rat bit the line and the damage to the house is over $100,000. dollarsOUCH!
