Repaired bumper, color and accident questions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by seeh2o, Jul 10, 2005.
  1. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    I just had my bumper replaced, someone rear-ended my car. I brought the car home yesterday afternoon and it seems like the color of the bumper is a bit different than that of the rest of the car. Mine is a 2004 Prius, it is parked outside all the time, so here in Los Angeles that means it gets A LOT of sun on it. Is it possible that the color difference is because the rest of the car has been out in the elements? The car paint looks like a warmish white compared to the bumper which looks more like a cold white or blue white.
    Also, I've never been in an accident before, so I didn't know what to expect. Both my insurance (21st Century) and the guy who hit me (his insurance is State Farm) recommended this body shop. The people were very nice, received an estimate, but I never received any paperwork when I picked up the car. Shouldn't I have received paperwork itemizing what was actually done vs what the estimate said and, shouldn't there be some kind of paperwork stating a guarantee or warranty on the work?
    Thanks in advance for help/advice for this accident newbie!
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    [font=Comic Sans MS:9cbfa2d7c5]You should absolutely get paper work, and you should also get your bumper repainted to match your car. I suggest you take it back and tell the body shop that you are not satisfied with the work since the colors don't match. White can be hard, but if it's a good body shop, they can do it.
    If you don't get anywhere with them, call your insurance company. They should go to bat for you to get your car looking like it did before the accident. An insurance claim isn't settled until you are satisfied.
    And get an itemized receipt and guarantee of workmanship when you are satisfied.[/font:9cbfa2d7c5]
  3. GKarschnick
    GKarschnick New Member
    50
    Melbourne, FL
    I noticed the same thing after my car was rear ended. I took it back to the body shop and the owner told me that the paint will appear slightly "different" on the plastic parts as on the metal. The angle of the sunlight at the time will emphasise the difference. We turned my car around facing the sun and the same difference was seen on the front-end plastic parts as compared to the metal. (Front end was new from the factory.)
  4. Tideland Prius
    16,660
    Our Camry's bumper looks goldish under certain lighting conditions even though our car is silver. I thought it was a manufacturer defect but I checked other silver Camrys and they have the same bumper effect. The slight mismatch maybe be due to the fact that the bumper is plastic and hence a tad harder to match to a metal body part even though the exact same paint colour was used. Check with them and see what's the colour code they used. Also, scope a Toyota dealer for a white Prius and check its colour against your bumper or the rest of your Prius and see if the paint decrepancies is due to parking your car out in the sun.
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    just had the front bumper on my Classic replaced and the body shop manager wouldn't paint it till they had it on the car so the painter could exactly match the colour. His painter just adjusts the color to match the car. Said he has a tough time with Toyota colours because they don't always exactly match the paint code for the car and say's the bumpers are the worst. The paint for the bumpers has a flex agent added to it so it won't crack as easily on the flexable bumper.
  6. cybele
    cybele New Member
    406
    Los Angeles
    I had an accident back in Jan '04 and had to have the front passenger quarter panel de-dented.
    What that body shop said they did was feather the paint into the adjoining areas to eliminate any abrupt color differences.
    Of course my car was only a month old and hadn't much fading yet, so it still looks like a great, seamless job to me.
    I don't know if the same can be done with a bumper replacement or not.
  7. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Paints do fade. Quality body shops use a computerized color matching system with a spectrograph.
    My car was repaired in February at Keyes Collision Center in Van Nuys. The color match on both the metal and plastic parts was perfect. The repair cost the insurance company (the driver at fault and I were both insured by the same insurer) 50% more than the original estimate by "recommended" shop .
  8. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    Ironically, I passed right by there on the way to pick up my car. I will go back to the shop this week to see what they say. I did look at my front bumper, it does appear to be the same as the rear bumper - a cold white, as opposed to the body, which appears to be a warmer white.
    I'll be sure to ask for an itemized receipt and warranty.
    I'll report back on what they say.
  9. geckoboi78
    geckoboi78 New Member
    53
    Va Beach, VA
    Don't know if someone answered this already but on my salsa red, the paint isn't going to match on the bumper and the car due to the material that each is composed of. I noticed that the first day I got mine and since then I notice it on a lot of new cars as well.
  10. c4
    c4 Active Member
    607
    51
    Sometimes if the body shop just uses the paint code vs. matching the actual paint color, you'll end up with a discrepancy between the existing body and the new part..
    Another possibility is the color of the primer/base coat. Assuming the same color primer coat/base coat was used on all parts, metal and plastic should come out exactly the same color.. Because paint is not opaque except in really thick layers, with the typical 2-3 coats, if a different color base (or no base at all) was used, then there could definitely be some difference in appearance, especially with light colors like white, gold or silver..
  11. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    Update!
    Thanks to everyone for your insight and advice. I took my car back this week and they were very gracious about it. The guy who owns the place took one look at it and saw the problem right away (why he didn't notice it when he handed me the keys the first time is another question). Anyway, they rented a car for me, I drove a PT Cruiser around for a day and half. It was like driving a lead-lined shoe box, but hey, it was free!
    I picked up my car yesterday afternoon, it looks 100% better. They also tossed in repairing and painting the underside of my front bumper for free. I used to drive a Ford Explorer, so I'm not used to a low clearance and did a mighty good job scratching up the underside of the front bumper. It all looks new again!
    They also gave me an itemized list of what they did and a lifetime guarantee.
    Thanks again for the insight and advice!
  12. Bill Merchant
    4,096
    87
    [font=Comic Sans MS:1f8a6b39fb]I'm glad it all worked out for you just right, like it's supposed to![/font:1f8a6b39fb]
