Repairing a rear strut
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Trey hollingsworth, Mar 22, 2018.
  1. Trey hollingsworth
    Trey hollingsworth New Member
    New Orleans
    I
    The bolt that goes through the lower end of the rear passenger shock is stripped and I was wondering is it a bolt that I’ll have to replace or is it welded to the suspension?
    #1 Trey hollingsworth, Mar 22, 2018
  2. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    Pop it out, go to auto parts place and get new one with a new nut too.
    Trey hollingsworth likes this.
  3. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    It's not welded.. use a mallet or a hammer and it should come out. Just grab another one from toyota.
  4. Mendel Leisk
    38,889
    I would go with the Toyota bolt, ensure it's the right grade.
  5. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
  6. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    I don’t think the bolt is simply removable. If that’s the picture from your Prius it doesn’t look bad. Just use a thread chaser (thread die) to go through it and it should be fine.
    That’s not the correct bolt and nut! Those attach the rear axle beam to the body. OP is talking about the nut and bolt that connects the rear coilover to rear axle beam. Here is the diagram that shows the correct nut:
    Каталог запчастей TOYOTA и LEXUS
    The correct nut has the part number 90178-14004.
    SFO and Patrick Wong like this.
  7. Patrick Wong
    18,200
    6,479
    A new nut should come with the new rear shock. I agree with valde3 that the OP should try to repair the stud threads if possible.
