Repeated P013A (O2 Sensor Code)
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by SK00TER, Apr 22, 2025.
  1. SK00TER
    SK00TER New Member
    BC, Canada
    2023 Prius Prime
    XSE Premium
    Hey all,
    Long time lurker and decided to make a proper account and join the forum!
    Diving right in, does anyone else get repeated P013A codes?
    (O2 Sensor Slow Response - Rich to Lean, Bank 1 Sensor 2)
    Context:
    I got my 2023 Prime XSE Premium last November. This code has appeared 3 times now since last September... The 2nd time the check engine light came on the estimated fuel mileage dropped considerably. A 20km trip would see a 40-50km reduction in estimated distance remaining. Toyota replaced the rear O2 sensor and that solved it for maybe a month or two.
    Sitrep:
    The code came back a 3rd time and my Prius has been at the dealership for a month now... Service department have been helpful and providing weekly check ins. Unfortunately they seem completely stumped and apparently in regular contact with Toyota HQ. They claim to have already inspected the sensor, catalytic converter, muffler, etc. They also tried to determine if there's a pinhole leak somewhere. After considerable back and forth with Toyota they are quote "getting ready to load up the part cannon" and just swap in new parts and hope it solves it. Fingers crossed it does just that.
    What if this keeps happening when the 3 year warranty expires next year? I assume Toyota would claim it is not a hybrid component and isn't covered under the 8 year warranty. Either way this seems odd. Is this a known issue with the 5th gen? Could this be a potential lemon issue?
    Any feedback and suggestions are welcome.
    Thanks!
  2. Trollbait
    12,539
    That would fall under the emissions warranty in the US, which is much longer than the bumper to bumper one.
    daisy555 likes this.
  3. SK00TER
    SK00TER New Member
    BC, Canada
    2023 Prius Prime
    XSE Premium
    Right, I thought the same as you. Then I double checked and perhaps it's a bit different in Canada.
    My coverage has both a 3 year and 8 year warranty for emissions. Depending on whether the components are classified as ITEM 1 or ITEM 2 determines which warranty they fall under.
    An O2 sensor is an ITEM 1 component (3 years). Some exhaust components are also ITEM 1. Whereas a full catalytic converter is ITEM 2 (8 years). I intend to keep a close eye on the parts replaced and hopefully avoid having to go through additional sensors when the 3 years are up. But at this point I think the O2 sensor issues are a symptom of something else.
  4. JJNY
    JJNY Junior Member
    22
    NY, NY
    Once had a car with repeating O2 sensor issues. Turns out it needed an engine replacement. There was a slow coolant leak into a cylinder and I was messing up the sensors...
  5. BiomedO1
    BiomedO1 Senior Member
    3,614
    1,869
    SacTown, Ca
    IMHO; I'd take the car to another dealership. While the one your going to seems nice; they don't seem to know what they're doing. Sorry
    They have the OEM diagnostic tool and can access the sensor data directly. That data should show them what's in tolerance, out of tolerance and what's borderline passing. I don't see how they can't figure out the problem. I'm assuming the car was bought used and the previous owner probably monkeyed with something. Again; the dealership should be able to nail that down with the OEM diagnostic tool.
    Good Luck.
    FWIW; dealership computer systems are linked, so the new dealership should be able to see what was done and tried at the other dealership.
  6. SK00TER
    SK00TER New Member
    BC, Canada
    2023 Prius Prime
    XSE Premium
    JJNY - Thanks for the insight! I'll ask during the dealerships next check in if that has been considered.
    BiomedO1 - Thank you for confirming the doubt that has been growing in the back of mind hahaha.
    Based on the CARFAX I got before buying this vehicle in Nov it was used as a "fleet vehicle" for a dealership... Perhaps that's a red flag that I should have paid more attention to? Either way, perhaps they tinkered with something that isn't reflected in the service history.
    In any case I'm starting to suspect this particular dealership doesn't have a hybrid specialist and hesitant to mention it to me.
    Okay this is exactly what I had assumed, especially with modern hybrid vehicles. I tried to go to a different Toyota dealership for this 3rd code and they called me back saying "it's better to stick with the service department that has troubleshooted the issue thus far". Which I chalked up to "I don't want to have to pick up someone else's problem midway through"...
  7. SK00TER
    SK00TER New Member
    BC, Canada
    2023 Prius Prime
    XSE Premium
    Well this is getting fubar.
    I picked up the car today after dropping it off on March 25th. Over a month of back and forth troubleshooting with Toyota HQ.
    They opted to replace sensor 2 again, which will make it the 2nd/3rd replacement of that part within the past year. Service confirmed that it is an ITEM 1 component so its warranty will expire next June.
    My wife took the car to work. Not even 40km after picking it up from the dealership: Check Engine Visit Your Dealer
    I'll use my OBD once she's back and see if it's the same code. Maybe it's something completely different this time. If it's B1S2 again then clearly it is not the issue and a reoccurring symptom of something else.
    I thought about taking it to another dealership but the steps and suggestions have apparently come directly from Toyota HQ. Maybe it's worth a visit to a different location so it can be handled by a different technician. I'm in direct contact with the advisor and assistant manager so I'll suggest it. Wouldn't be surprised if they latch onto that idea so they can dust their hands of this car.
  8. Dany Dan
    Dany Dan Junior Member
    43
    Québec, Canada
    2024 Prius Prime
    SE
    Possible cause of the code P013A:
    Manifold Break (Exhaus leak)
    defective catalitic converter or replace with a jobber
    Exhaus flight
    defective injector or jobber
    Mass Air Flow Sale
    DEFECTUE PCM or ECM
    etc...
    First test, injecting smoke under pressure into the exhaust to detect leaks.
    SK00TER and douglasjre like this.
  9. douglasjre
    douglasjre Senior Member
    2,180
    718
    Null, NL
    Can u let us know what it was after prob found?
  10. SK00TER
    SK00TER New Member
    BC, Canada
    2023 Prius Prime
    XSE Premium
    Thanks for this, I'll ask them if these possible causes have been considered yet.
    Absolutely. If the problem is ever found lol.
  11. SK00TER
    SK00TER New Member
    BC, Canada
    2023 Prius Prime
    XSE Premium
    TL;DR Update: A month has passed, code still frequently reappears. My Prius is back at the dealership again for who knows how long. Still no confirmed cause or ETA for when this will be resolved. An off the record admission echos a previous reply on this thread.
    Update: Another month has gone by... I spoke with the Service reps at the dealership. They seem to be getting agitated with the tedious back and forth troubleshooting, recommended procedures and due process HQ are putting them through. We agreed for me to take the car back and continue monitoring it rather than them holding onto it for extensive testing. That went on for about 2-3 weeks. I then provided them a report log in the following format:
    DATE CODE CLEARED: May 10th - 5:01 am
    ODO CODE CLEARED: 39320km
    DATE CODE RETURNED: May 19th - 7:39 pm
    ODO CODE RETURNED: 39939km
    RETURNED CODE: P013A7C
    DRIVING MODE: HV
    NOTES:
    - Prior to the code, vehicle was driven on pure EV range for a few days
    - Charged numerous times until HV mode was enabled after EV range depleted
    - EV range was not utilized from that point on
    - Fuel was fairly low and tank was completely filled on May 16th at 11:41 am
    - Code reappeared a few days later
    The code kept coming back fairly quickly whenever the ICE was engaged.
    Within the past month I got 3-4 repeat codes, it's clear that the code is permanent. I also am starting to notice a potential pattern of when the code reappears. When the fuel tank is 1/2 full or below, I do not seem to get the code that often, if at all. I am not certain, but it seems like the code appears more often when the fuel tank is above 1/2 to full.
    The car is back at the dealership and Service did what they could to encourage me they will fix it for good this time. I am not that optimistic at this point. To their credit though, they provided me a same year Toyota hybrid as a courtesy car to hold onto until the Prius is returned to me. I also got a brief window of honesty when picking up my car back in early May... I have been very calm, patient and understanding with the Service team throughout the process. Who have been immensely grateful for that to the point they pulled back the curtain a bit:
    "Off the record... We've seen this before. And in those cases it resulted in an engine replacement. There was a case at another dealership I was at where O2 sensor kept coming back and eventually the engine was ruined."
    You were right JJNY. At least that seems to be where my situation is likely headed.
    Only problem is Service (understandably) seem tied to the due process and feet dragging of HQ before they will approve a full engine replacement. Since that would be completely covered under warranty it is no wonder HQ seem hesitant, maybe even reluctant, to proceed with that decision until all other options are considered and vetted.
    douglasjre and Julio_E like this.
  12. douglasjre
    2,180
    718
    Null, NL
    Is your coolant level dropping? And is the problem go away if you leave the radiator cap loose?
  13. SK00TER
    SK00TER New Member
    BC, Canada
    2023 Prius Prime
    XSE Premium
    Good question, I will start to monitor that and reach out to the service team for what the expected reduction / levels should be.
    TL;DR Update:
    - Auxiliary battery was no good and replaced
    - Engine ECU was replaced
    - I picked up the car and will monitor the situation to see if the code comes back
    Detailed Update: Toyota Service provided me the following assessment.
    P013AC A/F SENSOR - RICH TO LEAN BANK 1 SENSOR 2 SLOW RESPONSE. RE- CHECKED ALL THE CONNECTOR FROM A/F SENSOR TO ENGINE ECU AND MAKE SURE THERE'S NO INTERFERENCE BETWEEN THE TERMINAL TO THE SENSOR. CHECKED TERMINAL OF ECU TO MAKE SURE TIGHTNESS OF ALL THE TERMINALS, ALL FOUND OK AS OF NOW. RESET SYSTEM ECU AND PERFORMED CONFIRMATION DRIVING PATTERN AND THE JUDGEMENT RESULT IS ABNORMAL P013A7C IS TURN ON. REMOVED EGR SYSTEM TO CHECKED FOR CARBON DEPOSIT AND CHECKED EGR OPERATION, FOUND NORMAL AS OF NOW. CHECKED INTAKE MANIFOLD FOR LEAK AND FOUND NO LEAK. CHECKED AUXILIARY BATTERY AND FOUND BATTERY IS WEAK. RECHARGED 12V BATTERY AND PERFORMED LOAD TEST VIA GR8 AND BATTERY FAILED LOAD TEST (CODE DCACMG3GDPPFEG). RECOM TO REPLACE AUXILIARY BATTERY (GSYUASA). REPLACE AUXILIARY BATTERY. PERFORM ACTIVE TEST USING GTS (CONTROL THE INJECTION MODE) FOUND WITHIN SPEC. CHECK IF VEHICLE HAS RUN OUT OF FUEL IN PAST, DID NOT RUN OUT OF FUEL.
    READ VALUE USING GTS (FUEL PRESSURE (HIGH)), FUEL PRESS IS NORMAL.
    PERFORM ACTIVE TEST USING GTS (CONTROL THE INJECTION MODE (DIRECT)), TEST RESULT IS NORMAL. RECOM TO REPLACED ENGINE ECU.
  14. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    You might want to try a smoke test. A machine like the Ancel S3000 can do this.
    You fill the smoke machine with a fluid of glycerin and distilled water. Then, you unfasten the hose from your air cleaner and insert the smoke machine's "balloon," which inflates to create a seal. Then it blows the smoke into your air intake under pressure. You then carefully look all over for any smoke seeping out of anything.
    What's the point? Your engine mixes fuel and air. There's a computer that controls this. It uses sensors to measure how much air comes in, so that it can create a perfect ratio of fuel and air. You then have two oxygen sensors on the exhaust: One before the catalytic converter, and one after. Their purpose is to first ensure that the burnt air/fuel mixture is correct, and the second ensures that the catalytic converter is working.
    If there is a leak anywhere in the air intake system, the sensor measurements will be wrong, and this system cannot function properly. A smoke test helps you find these leaks, if they are present.
  15. Kritt
    Kritt New Member
    2023 Prius
    XSE Premium
    Is it fixed? Curious what is the root cause. Thanks.
    douglasjre likes this.
