Replace ABS: how often is buzz sound
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ccna101, Jan 17, 2025.
  1. ccna101
    ccna101 Member
    95
    27
    SFO/IAD/DCA
    2020 Prius Prime
    So I am scheduling for a dreadful ABS (used) replacement ... what is the chatting/buzz sound would a normal ABS functional ? from my typical gen 2, a compressed during starting up and thing should be quiet for a while, unless. braking is apply during say- traffic jamp ???
  2. ChapmanF
    17,257
    What seems kind of normal to me is once when you open the driver's door after sitting for a while, and once every few uses of the brake. How many a 'few' is depends on several variables including how hard you apply the brakes.
    What you don't want is for it to sit there repeatedly pumping for its own private reasons when you're not even applying the brakes.
