Replace blocks or get used hybrid battery
Discussion in 'Prius c Main Forum' started by ZackG, May 28, 2021.
  1. ZackG
    ZackG New Member
    Do you guys think it's better to replace blocks or get used hybrid battery from a junk yard? (2012 Prius c 186k miles)
  2. Zhi
    Zhi New Member
    2015 Prius Plug-in
    If you can get the junkyard battery with a guarantee and at a decent price, that an entire used pack would probably be the better option. However If you can't get the battery with the ability to return it if it turns out bad, then recondition/rebuilding the battery yourself may be the route to take. Keep in mind you're going to need some specific equipment and tools to tackle a recondition/rebuilding project.
    49,489
    or new cells from 'newpriusbatteries.com'
  4. Leadfoot J. McCoalroller
    7,173
    6,719
    Pennsylvania
    2018 Prius c
    if you can get a good deal on a 2016 or newer battery, go for that. But there is no point in putting in another old one.
    Changing individual blocks isn't cheaper, but it is more "pay as you go" because you keep having to do it.
    Good luck!
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Neither.
    To have a reliable car again, you NEED all new cells in the battery pack.
    Which means a new pack or some labor to put new cells in your pack frame.
