Replace brake booster/accum+master cylinder and now touchy brakes
Discussion in 'Prius v Technical Discussion' started by douglasjre, Oct 4, 2023.
  1. douglasjre
    douglasjre Senior Member
    1,877
    653
    Orlando, FL
    Replaced the above but brakes r touchy as heck. No codes and did the linear valve calibration. Is it possible they sent me the 3rd gen kit instead?
  2. Mendel Leisk
    38,726
    Persistently touchy? I get touchy brakes once in a long while, just after start up, usually in reverse; invariably (so far…) they're back to normal once I get underway.
    It is weird; brakes are off or near-locked, nothing in between.
  3. douglasjre
    1,877
    653
    Orlando, FL
    Yup persistently. Short pedal mvmnt results in big brake application
  4. V Sport Wagon
    V Sport Wagon Member
    227
    83
    1) Did you give them your VIN when you ordered the part?
    2) Did you use Autel/Tech Stream to bleed and run the tests after the install?
  5. douglasjre
    1,877
    653
    Orlando, FL
    Didn't want vin. Techstream 4eva
  6. V Sport Wagon
    227
    83
    VIN is absolutely necessary so they can match the correct part number to your exact package car. There's a difference in compatibility especially between stock wheel sizes that can make or break (brake no pun intended) the installation. Good Luck.
  7. V Sport Wagon
    227
    83
    Double post, disregard…
    #6 V Sport Wagon, Oct 9, 2023
