Replace Cabin Air Filter
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Rangerdavid, Jan 24, 2017.
  1. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    so I took my 2016 in today for the 5000/6 mo. service and they said everything looked good but the cabin air filter needed changing out. Toyota wants $55.00 to do this. I think that is excessive. How hard is it to change the cabin air filter on a 2016 Prius? I can find videos for older models, but not the 2016. Help!!! :)
  2. Mendel Leisk
    41,926
    There is no effing way the cabin filter needs changing at 5000 mi / 6 months. Yeah, pop out the glove box and have a look for yourself. There's probably some tabs or tangs around both sides that need to be flexed in a bit, and a damper that needs unhooking at the outer end. Finally lift the glove box off it's hinges, and lift it out. Then just follow your nose, there'll be a little plastic door in there somewhere.
    In the manual, page 621, 622.
    FWIW, we're at 65K km's and 6.5 years, still on original cabin air filter. Every year or two I take it out and blow some compressed air through it.
    #2 Mendel Leisk, Jan 24, 2017
    ETP, mdmikemd, bisco and 3 others like this.
  3. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    Looks like a pretty straightforward job (y)
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Take a look on youtube, lots of helpful advice (at least there is for the 2009 Gen II) - $55 for a job which takes all of 30 seconds (45 if you need to unload the glove-box), at least that's about what it takes for the Gen II. My Stealership charges ~$105/hour (I think), but even at that rate, there's no way it takes ½ an hour plus!!! :eek::eek: Well, you've come to the best place for really great advice, but beware, PriusChat is addictive!! ;) Good luck!
    mdmikemd, RCO and Rangerdavid like this.
  5. Rangerdavid
    1,362
    52
    Three Touring
    Thanks guys, looks almost the same as my 2006 Prius was, so I think I'll buy a cabin air filter for $12 at AutoZone and DIY!!
    Seriously, 2:51 is all it took this guy and he was filming!! Definitely a DIY job!!
    pilotgrrl, bisco and RCO like this.
  6. bigmichaelkim
    bigmichaelkim Member
    70
    US
    Yeah and the more you do these diy jobs the more you learn about your car. This community is great for really empowering us. Damn the stealer ship and now u can see for urself if those guys are actually liars. Tag the dealership and help everyone stay away. Good luck!
    William Redoubt and RCO like this.
  7. Prodigyplace
    12,683
    11,833
    Central Virginia
    Careful! in my experience, Toyota filters look better & last longer than many of the auto parts store filters. I usually order my Toyota filters from Amazon.
  8. yeldogt
    yeldogt Active Member
    810
    313
    NE
    They make two filters -- one with charcoal. That one is more $$ ... My lexus has free maintenance so they change it.
    I buy the OEM Denso from Autohaus or the OE from an online dealer if I'm servicing the cars w/o needing enough stuff to hit free shipping at Autohaus.
  9. bisco
    52,404
    if the air where you live is clogging your filter at 5k, i would use a charcoal filter and a gas mask.
    Patrick Boase, kenoarto, Howe and 5 others like this.
  10. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    My KIA had replacement every 15,000 kilometres - I asked to see it one time, and, yes it was quite dirty. Unless you use recirculate on Climate Control, ALL the air coming into the cabin comes via the filter. I'm not sure if it's washable? TOYOTA doesn't suggest so, but a mechanic wouldn't do that if he can replace a part.
    How to change it is in the Manual - here is the first of a few pages:
    Choroidal, pilotgrrl, pjm877 and 2 others like this.
  11. bisco
    52,404
    i changed mine at 30k, cause it's hard to tell if the charcoal is dirty.
    pilotgrrl, RCO and alanclarkeau like this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    I replace the engine and cabin filters recently on our Gen 2 with STP filters. Neither one fit correctly. It was a simple matter to make them fit, but I won't be buying that brand again.
  13. Mendel Leisk
    41,926
    Maybe just check the one in there first; seems like your dealership is completely blowing smoke. Unless your environment is per bisco's description:
    Replace Cabin Air Filter | PriusChat
    RCO, alanclarkeau and jerrymildred like this.
  14. jerrymildred
    11,517
    14,158
    Tampa, FL
    I would be amazed if you really needed to change it this soon unless you've been driving through forest fires and sand storms. A lot!
  15. Mendel Leisk
    41,926
    Or a sheep shearing marathon? (n)
    kenoarto, pilotgrrl and jerrymildred like this.
  16. alanclarkeau
    7,045
    7,593
    I found small (dead) insects, pieces of wings and what looked like grass seeds etc in the one from the KIA.
    pilotgrrl and RCO like this.
  17. bisco
    52,404
    'grass' seeds?:whistle:
    Geo Dude, Howe, pilotgrrl and 4 others like this.
  18. Mendel Leisk
    41,926
    My hunch: the dealership didn't even looked at the filter, and it's fine.
    kenoarto and William Redoubt like this.
  19. alanclarkeau
    7,045
    7,593
    That's what they looked like - tiny. I'd been touring "out west".
    I'd driven through a plague of locusts (small grassshopper like insects) which were a pain to remove:
    upload_2017-1-25_12-26-21.png [​IMG]
    When I stopped at a fuel outlet to clean my windscreen - washers didn't do anything, there were big trucks stopped, and the drivers underneath raking locusts from their radiators.
    Sommer86, pilotgrrl, RCO and 2 others like this.
  20. bisco
    52,404
    now that's the australia we americans know and love.:p
    Geo Dude, RCO, jerrymildred and 4 others like this.
