Replace Chain Tensioner, gasket and Timing Chain(s), and associated guides ?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by PriusNeckBeard, Jun 1, 2023.
  1. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    @Mendel Leisk
    @Raytheeagle
    @Leadfoot J. McCoalroller
    @JimboPalmer
    @bisco
    Question about timing chain(s)
    Thanks so much for some info
    The Backstory:
    2013 Prius. 179,000 miles
    Chugging when engine first kicks in + check engine light
    A Prius specialist scoped it, etc
    "It's the head gasket"
    (FWIW I am weighing repair that vs replace engine with a re-built)
    Either way:
    IF I plan to stay in this car long term,
    AND replace the head gasket now,
    The specialist recommends:
    Replace/etc:
    Chain Tensioner
    3 Chain guides
    Timing Chain $421
    Plate
    Timing Chain $181
    Chain Tensioner gasket
    Total - About $1,100
    Should I do that?
    car is worth $10,800 if nothing had gone wrong
  2. Mendel Leisk
    41,457
    Not sure about your list; maybe just replace if warranted, when it's opened up?
    I would get the Toyota gasket kit, includes head gasket and all the pliable seals. gaskets, o-rings. That's around $200~250 IIRC. Also replacement head bolts, just to play it safe. A set is around $100?? Part numbers for both in the attached.
    There's a couple of head gasket related links in my signature.
    PriusNeckBeard likes this.
  3. Leadfoot J. McCoalroller
    8,088
    7,568
    Pennsylvania
    2018 Prius c
    Take an honest look at what $11k can buy you on the market today. From my end of the world... it's not great. Do you see a better deal? Is financing [your transportation problem] somehow more palatable?
    That's what you need to be thinking about.
    You'll get better prices thru cross-shopping, but they could involve long distance towing to begin the repair, no free lunch. I still recommend any independent shop before Toyota dealers- but it's best if they already have real hybrid experience.
    Good luck!
  4. Kerrynzl
    Kerrynzl Member
    New Zealand
    2016 Aqua
    Phone around and see if you can get a replacement engine [jap imported]
    Then sell off your old engine
    Generally these things are so reliable that the engines are cheap
    In NZ I can get a 1nz-fxe from a dismantler for NZD $500 [USD $300] with a 3 month warranty.
    Trade Me
