replace hv pack with ford escape NIMH cells
Discussion in 'Gen 2 Prius Technical Discussion' started by 2005pluginhybrid, May 20, 2019.
  1. 2005pluginhybrid
    51
    25
    vancouver
    I am considering replacing my stock pack with a Ford escape hybrid pack, or 2.
    I read on here about spoofing the sense lines with a series of 1k resistors to the sense lines.
    the prius uses NIMH cells configured as 6 cells at 1.2 v per module, with 28 modules = nominal 201.6 volts.
    the escape uses NIMH too. configured as 5 cells at 1.2 v per module.
    This would work out to 33.6 modules, unfortunately not an even number of modules.
    I am thinking of trying using 34 modules which would be a nominal 204 volts.
    Since the Pius doesn't use the full range of power, I hope this is close enough.
    I will manually wire out the sense leads to start with and occasionally verify the cells are balanced.
    The escape has connections at 6 volt points as opposed to 7.2 for readings
    I like the ford escape cells, because every pack I have opened have virtually no corrosion.
    If I am missing something here, or if anyone has a link to an easy way to monitor the new pack, let me know.
    I have some experience with the arduino
    SFO likes this.
    49,493
    sounds like you're all over it. please keep us posted and all the best!(y)
    ps, i would love to see two packs installed.
  3. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    So any updates on your install?
    49,493
    do we ever?:rolleyes:
  5. bisco
    49,493
    it all sounds so easy when you're lying awake at 3 in the morning...
    R-P likes this.
