Replace hybrid battery?
Discussion in 'Gen 3 Prius Main Forum' started by Neohippy, Jan 21, 2018.
  1. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    My 2011 the yellow triangle came on and said replace hybrid battery. I just bought a brand new 12v one battery it reads 12.56 at the battery when hooked up. I cleared the codes and it still said replace hybrid battery. The car only has 82k on it. Any ideas? I’m getting P3190. The engine starts and runs and also shuts off lol me it normally does when driving. As soon as you let off the gas it stops running
    #1 Neohippy, Jan 21, 2018
  2. JC91006
    16,482
    8,397
    There are 2 batteries in the car. 12v which costs $200 and hybrid battery which costs $2000+
  3. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Let a dealer look with their equipment, any rodent signs in or near the car?
  4. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    How long have you owned this car?
  5. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Get the car scanned, and you start onwards from there.
    Without the scan for codes, you're just throwing parts at the car, which it would, gladly accept:D
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    If a P3190 code is displayed, 2 things worth checking:
    • How much gas is in the car?
    • The fuel pump
    Do you have Techstream to check on other codes?
    What is the hybrid battery state of charge?
    Keep us posted (y).
    m.wynn and JC91006 like this.
  7. bisco
    49,446
    why are you deleting codes? you're under warranty, get thee to a dealer for a free hybrid battery!
    Prieth, padroo, Johnny Cakes and 2 others like this.
  8. JC91006
    16,482
    8,397
    As Bisco says, you are under warranty on the hv battery. Get it to the dealer and they'll give you a new one
    Raytheeagle likes this.
  9. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    You have a long, full warranty on the entire hybrid system stem to stern, go to the dealer!
    audiodave likes this.
  10. Blegate
    Blegate Prius Gen III 2013
    132
    Vancouver, WA
    What was the resolution? Anytime I change out the 12v bat in the back the car runs funky and has error codes. I typically drive it 1/8th of a mile, turn it off and back on....then all is good.
    padroo and Merkey like this.
  11. padroo
    padroo Senior Member
    2,763
    2,250
    There is a relearn procedure the car has to go through because you just erased it's memory.
    There are ways to keep this from happening though.
    Merkey likes this.
  12. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I love these post where the OP just stops communicating.
    strawbrad likes this.
  13. Neohippy
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    After replacing the battery I drove it a few miles and once I turned it off and back on it started running fine again. Haven’t had any problems again.
    Andyprius1 and Raytheeagle like this.
  14. bisco
    49,446
  15. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    I am surprised to read this with so few miles on a newer Prius. Has this happened with other gen 3 owners? We are almost at 80k on her 2013. Should I be concerned?
  16. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Nope;).
    Currently a tick under 176 k miles on our 2010 and it’s going strong:).
    But I also do some preventative maintenance that may help;).
    This is what I am in the middle of currently:
    Just checked and it’s at 239 volts, so about ready to start discharge cycle #1(y).
  17. stephensprius
    670
    226
    Thanks! that's interesting. Is there regular maintenance that one can do with the hybrid batteries? We do take it to the dealership. They have been most fair with pricing and I feel they are the experts in our area with hybrid vehicles.
  18. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    What the picture is of is the Hybrid Automotive Prolong battery charger;).
    This allows you to grid charge your hv battery pack. Pair that with their Intelligent Discharger and you can easily maintain your hybrid battery :).
    I started this process when we were just outside of the 10/150 warranty (I hit mileage first). First top end balancing I did rejuvenated the pack and has been performing better with occasional preventative maintenance ;).
    You are near a Prius expert: @strawbrad :).
    Hope that helps(y).
    stephensprius likes this.
  19. stephensprius
    670
    226
    Is any of this done at the dealership for regular service intervals? I am not very savoy with batteries or maintaining the vehicle. Is there someone that can explain how to do this, with instruction?
  20. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    It’s easy once the harness is installed ;).
    Here are some pictures, for reference:).
    The harness that connects to the battery and allows either the charger or Intelligent Discharger to be connected:
    How to connect the harness and 120 volt power as well as turn the charger on:
    Similar for the Intelligent Discharger:
    214257E6-C8AA-432B-933A-084F8A2B0B4F.jpeg C8E5EC5C-FC4A-4148-AF0D-12C7586AB0DF.jpeg
    There are more buttons on the Discharger, but all is explained on the Hybrid Automotive website ;).
    This includes instructions and pictures on how to install the harness :).
    There is an installer map on there as well. I paid to have our harness installed and since it was @jeff652 , it was a good excuse to ask questions ;).
    Hope that helps(y).
