Replace ignition coils with spark plug?
Discussion in 'Prius c Main Forum' started by xecure, Apr 2, 2024.
  1. xecure
    xecure Junior Member
    Bay Area
    2015 Prius c
    Hello, I have a 2015 Toyota Prius C with about 88,000 miles on it. I'm about to do a couple of maintenance on it, one of which is the replacement of the spark plugs. I'm wondering if people here recommend changing the ignition coils along with the spark plugs? How can I see if the ignition coils are worn out or not?
  2. John in Vermont
    John in Vermont Junior Member
    49
    Rochester, Vermont
    2018 Prius c
    The ignition coils don't need to be replaced. You can be sure that Toyota would recommend their replacement if it was even vaguely justified so they could generate more service income for the dealerships. Prius's are very low maintenance cars, don't start looking for trouble. My 2018 doesn't call for a spark plug replacement until 110,000 miles. I'm not sure if your older model needs to have the plugs replaced sooner.
    If you aren't experienced with replacing spark plugs, I strongly recommend that you get a torque wrench to do the job to avoid damaging the threads.
    #2 John in Vermont, Apr 2, 2024
  3. BiomedO1
    BiomedO1 Senior Member
    4,184
    2,187
    SacTown, Ca
    There really isn't a need to do either. They are iridium plugs and can easily last more than 150K miles. I didn't run into ignition coil issues until around 250K+ miles. The engine will intermittently miss under load. At that point, replace them all instead of trying to locate the intermittent coil - other will say. Just replace the bad one. If you got 250K miles out of the originals, I'd say it's time to replace them all in one shot - to avoid another one going out in an in-opportune time.
    Just my 2-cents.....
    #3 BiomedO1, Apr 2, 2024
    John in Vermont likes this.
