Replace motor mount
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by BrotherTeresa, Sep 21, 2023.
  1. BrotherTeresa
    BrotherTeresa New Member
    Ohio
    2012 Prius C
    I want to replace my motor mount on the passenger side due to rust and was wondering if anyone has tackled this and if so, is an engine lift necessary? Thank you.
  2. Leadfoot J. McCoalroller
    7,165
    6,713
    Pennsylvania
    2018 Prius c
    Motor mounts are one of those parts that can look terrible while being 100% effective. Are you sure it needs to be replaced?
    Mendel Leisk and PriusCamper like this.
  3. PriusCamper
    PriusCamper Senior Member
    11,095
    4,515
    Pacific Northwest, USA
    It's such a little engine there's not much issue with the mounts. However, when people have major engine problems it's always thoughts & prayers that it's just a bad engine mount.
  4. Palmoyas
    Palmoyas New Member
    Vermont
    Usually you'd use a jack underneath the car to raise/support the engine and replace a mount. I've never done a Prius though.
