Replace one cell or entire battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by joejudi, May 19, 2013.
  1. joejudi
    joejudi New Member
    2005 with 116,000 miles. Light signaled "go to dealer". Dealer ran codes. One cell was 13.95 volts. All others were above 15 volts. They recommend total replacement at $3,800. Is it possible, practical or logical to replace the one cell below 14 volts?
  2. bwilson4web
    15,518
    Possible, yes. Desirable, not without proper testing:
    1. replacement module needs to have the same Ahr capacity (measured) as the others
    2. replacement module needs identical charge state as the other modules
    In practice, this requires in effect rebuilding the whole traction battery. Then there is the problem of making sure the buss bars are OK. Often a failed module is associated with electrolyte leaking and this tends to corrode the buss bars and sense wires.
    Over the years, we've seen a high failure rate, ~2/3, after single module replacements in the 2001-03 Prius.
    You might consider adding your location to the profile. This makes it a lot easier to identify independent Prius shops that can offer you another option.
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved to the appropriate Gen II forum out of the Prius v forums.....
  4. Mendel Leisk
    38,705
    The common path of least resistance is to hand your battery over to a rebuilder in exchange for a refurbished one. They'll repeat the process with yours, balancing, replacing cells as needed, and so on. Re-Involt is one company in this business; I think they're refurb Prius batteries will set you back just under $2000, and you'll need to spend about another $300 with one of their authorized installers.
  5. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    There have been a couple of threads recently with people replacing cells. It is a learning process, and requires a good bit of your time. Although it is not difficult work, you will have to determine if your time is valuable enough to make going through the rebuilders mentioned above a good option..
  6. Kevin P.
    Kevin P. New Member
    Cathedral City, California
    I
    Prius Battery fails, just after warranty expires! Interestingly enough my flailing diminished power 2006 Prius limped into a Toyota dealership this morning, and received a diagnosis of "battery not performing as expected" and needs replacement to the tune of $3598.00!!!!! This is a Prius with now 160k mi, and apparently Toyota offers a 10yr / 150k mi. warranty...but it doesn't cover this one! Anyone else with similar experience? What are the alternatives to getting the battery replaced without the high price??
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
