Replace one HID bulb or both?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tkoegel, Nov 4, 2010.
  1. tkoegel
    tkoegel Junior Member
    Mill Valley, CA
    I have a 2008 Prius with a front HID bulb that is intermittently failing. I am a klutz with large hands, and so I am not inclined to try a DIY fix. I called the dealership for an appointment, and they (to my surprise) said there is no reason to replace the bulbs on both sides at the same time. Said that the labor for so doing would be about double--no cost saving.
    Is this right? I thought the cost involved (other than the super-expensive bulbs themselves) related to removing the bumper, and I would think that would make doing both at the same time a sensible approach.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Dude, you can do this, it's really not that hard.
    Ask a mechanically inclined friend to stop by.
    Have cold beer ready!
    How much did the dealer quote on the work????
    D4R bulbs on eBay are around $60 or so.......
    The labor they charge, unless they comp you, is nutz!!!
  3. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    replace both. The other will go out or do the same flicker thingy sooner than later. Both sides are not exactly the same amount of work if you don't take the bumper off. Lots of threads and youtube videos to study before you do the deed.
    I replaced my fogs and hid with 6k matching hence I took off the bumper.
  4. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
  5. KK6PD
    4,003
    944
    118
  6. priuslovers
    priuslovers Way Out Member
    65
    Hercules, California
    I have a 2005 and would like to change the fog light bulbs to
    LED's where did you get yours?
    Thank you, priuslovers.
  7. tkoegel
    Mill Valley, CA
