Replace Pistons/Rings vs New Short Block vs Ignore?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Apr 27, 2022.
  1. MrPete
    MrPete Active Member
    424
    171
    Colorado, USA
    So my 2011 Gen 3 has been eating oil since ~120k miles. More in the summer (almost a quart per fillup.)
    And now I've got the occasional rough-start-but-fine-if-power-cycle.
    So I'm looking at
    * EGR clean
    * Intake clean
    * OCC addon
    * HG replace
    The above will take time but not that much $$$.
    Given that I'm paying as much for between-fillups synth oil as for the oil changes... I'm wondering about the cost of just fixing the stupid problem once and for all.
    I see three options:
    1) Keep putting oil in. And hope the above fixes may help a little
    2) Change pistons and rings (presumably for the 2015 version) as described in T-SB-0169-16, nicely shared by @Mendel
    3) Find a 2015 short block and get that swapped in.
    I've searched and not found an example of anybody doing either #2 or #3 here. I'm wondering what the parts cost (or other significant cost) is for these, and how ridiculous it may be for me to make the attempt. (Given that I do have access to a friend who is both ASE certified mechanic and likes to help ;) )
    anonymous likes this.
  2. AzusaPrius
    AzusaPrius Senior Member
    1,819
    809
    I had a rebuilt engine put in with 2015 pistons and rings, all is good since then
    Oil level is right here it needs to be.
    Also coolant level has not moved.
    So the Felpro gasket they said to use is holding up just fine.
    Hybridpit.com
    You can also use code "azusa" to save!
    nate358 and PriusCamper like this.
  3. Paul E. Highway
    Paul E. Highway Active Member
    200
    127
    Hawaii
  4. Mendel Leisk
    38,635
    How about just replace the rings, with original, “low tension” rings? I know, but it’s cheaper and easier, and buys you at least another 100k miles?
  5. Tombukt2
    Tombukt2 Senior Member
    8,890
    1,549
    Durham NC
    We swapped in a used JDM thing in the oil is staying right where it needs to be everything running just fine and that didn't hardly cost squat so I can't see spending two grand for a short block and all that kind of stuff I mean the car is not going to be with you like that at this point and now I have two coolers for the EGR and extra head etc etc that i'll probably never do anything with and that fell pro gasket is a great gasket mine has less than 12 miles on it before the engine blew probably never get used again even though it could be
  6. MrPete
    424
    171
    Colorado, USA
    UPDATE and a resulting QUESTION:
    Here in Colorado at 7,000 ft, we don't plant gardens until Memorial Day (May 30) because frost risk is real.
    Well, the weather has mostly warmed up now.
    And with warm weather, I've had ZERO startup issues. Absolutely nada. And I've not had a chance to do ANY of my proposed fixes.
    QUESTION: does this mean anything? Is it possible I have no issue with my head gasket?
    This weekend, I am hoping to do at least EGR / Intake clean and add Oil Catch Can. Is it possible I'm going to squeak through without needing to do the head gasket?
  7. MrPete
    424
    171
    Colorado, USA
    @Tombukt2, what's a "JDM thing"? Certainly curious!
  8. Tombukt2
    8,890
    1,549
    Durham NC
    Japan domestic market it's an engine that hasn't been touched by people in America yet so low mileage take out from an Asian market car that's all a few people have put them in and fooled with them here with a zz engine the open deck way the engines built there are some inherent weaknesses and apparently piston crowns like to peel off the top of the Pistons or something I don't really know and I'm not fully interested in knowing I just wanted it out of there with the high miles that it had so I just put an engine and the transmission in the vehicle with way lower mileage than I could expect to find in the states and if I found similar mileage in the states would have been $3,000 for the pair not 1125
  9. MrPete
    424
    171
    Colorado, USA
    I think I'll let sleeping dogs lie on the JDM thing ;)
  10. MrPete
    424
    171
    Colorado, USA
    My new question above still stands: with no further startup hiccups, is it possible I have no issue with my head gasket?
  11. Tombukt2
    8,890
    1,549
    Durham NC
    It's possible you may have no further issues but generally it's more possible that you shall going forward mileage doesn't go down so it's just an inherent thing in some of these ZZ engines I have one in a Corolla that's had similar course of that 500,000 miles may have something to do with the type of engine stroke that we have it's not I can't remember the name of it but anyway who knows but it certainly won't get better it will get worse I would think
  12. PriusCamper
    PriusCamper Senior Member
    11,055
    4,498
    Pacific Northwest, USA
    What year was the rebuilt engine? Were the pistons and rings older or newer or same age as engine?
    #12 PriusCamper, Jun 1, 2022
  13. Tombukt2
    8,890
    1,549
    Durham NC
    So far running like a champ you can't even hear the damn thing when it's on inside the car out but no matter the one that we bought with it in there you definitely could and I didn't think there was anything really wrong with it when I bought it no lights on engine running like a Corolla 2z didn't think much of it and just another Prius
  14. AzusaPrius
    1,819
    809
    @PriusCamper
    The donor was a VIN verified 2010 and they installed brand new 2015 pistons and rings
    PriusCamper likes this.
  15. Tombukt2
    8,890
    1,549
    Durham NC
    Well I hope costs were not too bad . I'd hate to pay for internal engine work today. Was less expensive to me to get an Asian market take out . Just like actuator and abs pumps 150 bux vs what thousands .....
  16. MrPete
    424
    171
    Colorado, USA
    Most online JDM sources seem to be more than a little loose, just saying 2010-2015.
    Is it easy to get a trustworthy commitment, or do I need a large dose of buyer beware with JDM?
  17. MrPete
    424
    171
    Colorado, USA
    Time for an update...
    From my Heeeelp thread, you know
    1) my HG blew...
    2) I bought some time with HG liquid that is still working
    3) I visited a JDM source and learned that while they ARE nice low miles engines, most of them are early gen3, so I would be buying the same issue soon.
    We made it home.
    My dealer will sell me 100% of the parts for HG replace and the 2015 piston/rings swap for around $800.
    I would love to know what else is needed to do what appears to be a short block renovation. I am guessing some specialized tools.... and maybe worth hiring a specialist shop to do certain aspects?
  18. rjparker
    rjparker Tu Humilde Sirviente
    7,913
    4,676
    Texas Hill Country
    Doing the pistons and rings is an engine out job so you need a hoist and probably some help. Toyota says to drop the subframe, transaxle and engine. Most diy come out the top but risk the windshield. It seems quite a few problems occur with the timing even though everybody thinks they did it right. I would have the head rebuilt by a qualified machine shop. There is always the question of replacing this and that while you are at it.
  19. Mendel Leisk
    38,635
    This TSB summarizes a block rebuild.
  20. Tombukt2
    8,890
    1,549
    Durham NC
    We came out the top windshield was not an issue Hood stayed on the car stand straight up engine has plenty of room to come out the windshield wiper tray obviously is out not a big deal I was standing right there during the whole mess I wouldn't even attempt with Toyota parts or not to rebuild the bottom end on the fly without a lot of machine shop work and funny business so look for a JDM engine and maybe it's transmission and don't look back it's probably the cheapest thing you'll get away with doing
