replace rear axle as last resort to improve alignment
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by galileofigaro, Jul 15, 2021.
  1. galileofigaro
    galileofigaro Junior Member
    37
    2015 Prius Plug-in
    Yesterday my mechanic couldn't improve the rear alignment by installing rear camber shims. So last resort is to replace the rear axle beam, used for around $400.00 plus labor like another $400.00. New for $1200.00 no labor included.
    Any suggestions?
  2. Mendel Leisk
    38,662
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    It will take you a LONG time to recoup $800 in excessive tire wear by improving the alignment.
    Assuming that is the actual problem.
    I suggest that you need a second opinion before you drop that kind of cash.
    A large body shop with a good reputation often has an expert in things like that.
  4. ETC(SS)
    6,544
    ^ That.
    How bad was it hit in the rear?
    How "off" is the alignment?
    What prompted the alignment in the first place?
    How many miles do you drive in a year?
    City or Highway miles?
    +1 on the body shop!
    If your car was tweaked so badly that shims can't bring it back into geometry then you may be riding in a death trap.
    Or?
    Your car is nearly perfectly aligned and your mechanic is chasing after a bubble with your money to get it absolutely perfectly aligned.
    Or?
    Your car IS within alignment specs and you're trying to get 50,000 miles out of 40,000 mile tires without proper rotation strategery.
    Or?
    Your wrench is using a $99 Harbor Freight alignment machine.
    Either way.....if it were MY $800, My life, or both......I'd get a second opinion!
    The measurements don't look life-or-death bad to me, but I fix phones for a living, NOT cars.
    The fact that you're asking for advice on-line tells me that your Spidey Senses are tingling.
    Listen to them.
    Good Luck!
    #4 ETC(SS), Jul 16, 2021
  5. bisco
    49,399
    i would suggest we need more information, this is a very unusual move. all prius are out of alignment in the rear, that's how toyota designed and engineered them
  6. sam spade 2
    7,035
    2,788
    2017 Prius c
    I am in need of some phone software help.
    I am one of those that can't create a new private message conversation on here.
    PM me, please.......if you can.
  7. ETC(SS)
    6,544
  8. Bucky35
    Bucky35 Junior Member
    37
    NorCal
    Looks like your mechanic is no good with the shims. I have moved it more than 1 degree with shims, your after only shows 1/10 of a degree change which could just be measurement error. Are you sure they actually shimmed it?
    I used Specialty Products shims. The directions can be confusing and I have wasted a few by installing them wrong.
    You can get perfect alignment on the rear with shims, I have done both of my mine. You can also get perfect alignment on the front with Specialty Products camber eccentric bolts.
    nate358 and QuantumFireball like this.
