Replace stock AMP/Speakers
Discussion in 'Gen 3 Prius Audio and Electronics' started by ajc, Dec 2, 2009.
  1. ajc
    ajc Member
    340
    38
    pa
    I want to install new speakers and AMP but use the stock receiver.
    Has this been done and if so I have some questions.
    - Where is the stock APM located?
    - Can I replace the stock AMP with an aftermarket AMP and be able to use the stock wires?
    - Will the receiver and steering wheel controls still work?
    - any install pictures for this?
  2. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    On the top right of this page is a box called Google - try Googliing speakers replace... Also it helps to list what you have currently. If you have JBL, there's a thread on that (it's hard), if you're stock, there's a separate thread.
    You may just want to start with speakers, and then asses if you need an amp, or new HU...
  3. ajc
    ajc Member
    340
    38
    pa
    I did several searches and could not find it? Do you have the link to the thread?
