Replace tires on brand new Prius?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LDB, Sep 12, 2015.
  1. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    I got my 2015 a week ago. It has the Ecopia EP20 tires. Pros: they are LRR and they are on the car. Cons: they get mediocre ratings on tirerack from actual users. If the tirerack ratings are scored 1-5 points, ignoring the snow and ice categories being in Houston, the maximum points available to the categories that matter here are 40 points. The Continental TrueContact and Michelin Premier both score 40 points. The Ecopia EP20 OEM tires score 27 points.
    So, I've pretty much made my mind up to get a set of TrueContact based on #1 rating of all the tires on tirerack for OEM size and $80 each compared to $120 for the Michelin which is #2 of all the tires. I am curious what others think though.
    Also, basically brand new EP20's with under 400 miles when removed, any thoughts on selling the takeoffs as to what they're worth? Right now tirerack has them marked "special" and $89 so I thought $50 each would be a very good deal for someone else and for me.
  2. alekska
    alekska Active Member
    435
    138
    Atl
    I would repla
    I would replace them only if YOU are not happy with their performance, not because of lower rating on the Tirerack
    - Alex
    milkman44, xpcman and Mendel Leisk like this.
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    766
    302
    Maine
    Your existing tires will be fine for the next 30,000 miles. Leaving them in place and save yourself some grief. Somewhere after 30,000 miles the tires need to be replaced, then you can shop for replacement tires.
  4. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I would definitely keep them until they need replacing, especially in Houston. It's wasteful to replace new tires. Be thankful it didn't come with Goodyear Integrities like the 2nd-gen!
    dorunron likes this.
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    What is the treadwear rating on your tires? I would pump them up to max sidewall and get the most out of them that I could.
    Save the money for the new tires and the effort of selling the old ones. The retail tire rated on tirerack isn't the same tire as the OEM version.
  6. bisco
    51,154
    get rid of those pieces of junk, your life isn't worth it.
  7. Mendel Leisk
    40,583
    There's nothing wrong with the EP20's, they're a fine tire, good for LRR. My only quibble would be they get a little noisy when worn. Oh, and don't even think about venturing out in snow when they're worn. Both of those would apply to pretty much any all season.
    I've bought them as replacement a couple of times now, for a previous Civic Hybrid. Nice and quiet when new, track good, mpg doesn't skip a beat.
  8. LDB
    LDB Member
    279
    71
    My interest is the much higher ratings for braking and handling and the much better score for sound. I wouldn't think of it at all if I didn't think I could get at least half the cost of the new ones for the take offs.
  9. JC91006
    16,673
    8,518
    If you can sell the tires for $50 each, your trade up cost would only be around $200 total. Not the end of the world and it'll make you happy
  10. KenSoren
    KenSoren Junior Member
    31
    Yucaipa, CA
    The main thing is if you have the money and it will make you happy go ahead and do it.
    Putting up with a tire you don't have any confidence in for 20 to 35 thousand miles is not worth the worry.
  11. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    My experience has been different.
    My Prius came with Bridgestone Ecopias. I understand that they are not the worst out there but my experience was flat tires requiring tire replacement, road noise on rough surfaces, less secure handling than I would prefer at speed on freeways and relatively early loss of tire performance from hardening of the rubber.
    Changing to Michelin Primacy tires made a big difference.
    If I bought a new car that had Ecopias, I would probably get them replaced immediately with Michelins and resell them.
    If I bought a 2nd hand car that had them and they were in very good condition, Providing I wasn't about to do a long trip or a lot of winter driving, I would wait until the Michelin sale was on at Costco (twice a year IIRC) and replace them then.
    If I only drove locally on good smooth roads, with no significant time on busy freeways, my approach might be different.
  12. 348
    348 Junior Member
    71
    36
    Central Oregon
    Don't 'think', find out what they will give you.
  13. LDB
    LDB Member
    279
    71
    I would sell them myself. I doubt they'd give me more than maybe fifty dollars for the lot, if anything at all. I figured I would sell them on CL for $50 each since from a dealer they'd be around double that.
  14. 348
    348 Junior Member
    71
    36
    Central Oregon
    Ask them first! ......they could be with more or way less.
  15. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    I wanted to get rid of the 15" Yokohama Avids that came on our Prius since we bought the car. Mid rated tire. But the things were fine for the kind of driving we do around Maine and found them to be quite adequate for long distance travel. I couldn't complain about their hydroplaning resistance or traction on slippery surfaces. They finally wore out at around 52,000 miles. Were getting a bit noisy on the road, while wearing exceptionally evenly. Totally round, no flat spots or wobbles.
    I had bought a set of Persona 17" wheels in the Spring of 2014 when the Avids were starting to show wear and finally installed a set of Pirelli P7 Cinturato 205/50 17 on them this Spring. Took a while to get those Yokohama Avids to wear out. They thoroughly tested my patience by the time they were a millimeter from the wear bars. They probably would have lasted another 3,000 miles, but we were going on a 6,000 plus trip, so off they came at that point.
    Sometimes a mid rated tire isn't so middling. It's all about how you drive, what the road surface conditions are and what you're giving up for perceived performance loss on a car that is not really intended for track days.
    energyandair and Mendel Leisk like this.
  16. Mendel Leisk
    40,583
    ^ Listen to this guy, save your money. :)
    B. Roberts likes this.
  17. Roger T
    Roger T Member
    198
    48
    MA
    I have the same situation as OP.
    My Prius 2014 comes with EP20. It is really noisy when on non-smooth road. I have 26000 miles on it now. I will replace it with Michelin soon.
    The good thing is, it has really good MPG. Average 55 computer MPG in the past 1200 miles.
  18. B. Roberts
    691
    212
    Replacing with a good LRR should yield about the same MPG... only watch out for a slight decrease at first as the tire breaks in. I had not noticed that break in thing until I switched to the Pirellis and thought I would never again see 50 mpg plus. After about 1,500 miles... the mileage came back to our normal 52-54 mpg range.
  19. qdllc
    qdllc Senior Member
    1,371
    399
    Why would you basically waste something you paid for? Pick what you want to go with and make the switch when you need to change tires.
    Unless you know someone who will buy the old set off of you.
    348 likes this.
  20. energyandair
    905
    339
    Victoria BC Canada
    Depending on your use, it can also be about safety.
