Replaced 12v battery but prius 2005 will not start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Shoji023, Jul 27, 2017.
  1. Shoji023
    Shoji023 New Member
    Dallas, TX
    Car sat for 2 months and died. AAA jumped it. I drove it for 30 mins, parked, and it died. Couldn't jump it again so I replaced the battery. But it still won't even show that I am providing any power, even when I connect the Car jumper. Nothing.
  2. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Are you sure all the battery connections are hooked up? Even under the fuse box under the hood? Wrecker driver could have done anything.
    Any fuses blown?
    Did it ever start after the new battery was installed?
    Is something draining it dead overnight or a few days?
    Where are you connecting the car jumper?
  3. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    First thing to check is the 12v battery connections. Then main fuses.
    51,155
    especially battery negative to body.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Make sure the negative connection to the body isn't corroded or loose. Easily overlooked in the heat of battle.
