Replaced 12v battery - now get a warning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by golfclubs44, Jul 19, 2014.
  1. golfclubs44
    golfclubs44 Junior Member
    2006 model - sat for about 10 days - just replaced 12v battery - car starts, goes forward and reverse.
    However, when I put the car in drive I get the following on the display -
    Red Triangle warning and on the display it reads "Please press P to engage Park. The Battery will not be charged if the Transaxle is in N."
    Has anyone seen this or know what this is about. I didn't see anything in the ownersmanual.
    Thanks
    49,725
    could be the hv battery, how many miles on her? double check your 12v connections, especially where neg. attaches to body.
  3. Mylar
    Mylar Member
    163
    36
    Cincinnati, OH
    2019 Prius
    Yes! I get the same msg if I have the AC running while taking the car through the car wash. It means your traction battery is low. Drive the car around for a while and it will recharge and the error should go away.
  4. golfclubs44
    HV - that's the hybrid battery? If so, that was replaced 2 years ago - so basically new.
    I'll check the 12v connections.
  5. golfclubs44
    sounds good maylar - nice tip - and your's too bisco as I could have not fully connected the battery cables
  6. Former Member 68813
    3,524
    981
    US
    Means you have to shot it down and restart again. Some kind if glitch. I saw it in my 3rd gen too.
  7. bisco
    49,725
    sounds like mylar has it right.
