Replaced 12V battery...still won't start normally, no brake lights, traction control light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Marathon Jon, Nov 11, 2014.
  1. Marathon Jon
    Marathon Jon New Member
    Harvard, MA
    New to Priuschat -- we have a 2010 model III with 94k miles, garaged each night. Recently didn't start on cold morning, so I attributed it to the 12V battery. It tested bad, so I replaced it and measure open circuit voltage 12.7V, under load 12.4V with headlights on. With the usual starting procedure the information display reads 'Depress brake pedal to start'. I removed the brake switch and verified that both pairs of switch contacts change resistance when the switch is depressed (one pair from closed to open, the other pair from open to closed). With the switch reinstalled, it only starts ('Ready' illuminated) while depressing 'Start' button for about 8 seconds while steadily depressing brake pedal enough to activate brake switch. The Traction Control light remains illuminated once started and the brake lights do not illuminate when braking (this is also true when the vehicle is off). Vehicle may be subject to Safety Recall D0H (D1H) for brake booster pump assembly (accumulator) but I didn't have it checked yet and don't think this is causing the issue. Any ideas?
    51,155
    welcome to priuschat! how do you know the brake switch is being activated?
  3. JC91006
    16,674
    8,519
    What was the voltage of the failed 12v when it tested "bad"?
  4. Marathon Jon
    Harvard, MA
    I inspected the switch range of motion while depressing the brake pedal. I also hear a click sound which I interpret as the circuit closing (or opening). One thing I have not yet checked (due to safety of not having the brake lights working) is driving it at speed and setting the cruise control to see if it brake pedal deactivates it but I believe that is another switch anyway.
  5. JC91006
    16,674
    8,519
    A bad switch would set a DTC. Do you have anything to retrieve codes? You can also just buy a new switch and install it, it shouldn't be that expensive.
  6. Marathon Jon
    Harvard, MA
    Do you have any recommendations on a OBD code reader? I read that switches rarely fail, but could try a new one as well.
    To answer your previous post, the open circuit voltage on the old battery was 12.7V but I didn't read it under load. I simply noted slow wipers, slow power windows, and weak headlights before removing it and taking it to the shop to test it -- old one failed their test, new one passed same test.
  7. JC91006
    16,674
    8,519
    I find it strange it would go "Ready" if you hold the start button for 8 seconds. You would need to get a MiniVci with Techstream from Amazon.com. That is the most complete tool you can use to diagnose your car. You will also need a computer with 32bit windows to run the program.
  8. Marathon Jon
    Harvard, MA
    I also found it strange that it would go to Ready after that long. At first I was going on the theory of an intermittent brake switch contact and pumped the brakes while pushing the start switch for an extended period of time. After testing the brake switch I tried depressing and holding the brake pedal and I got the same result after 8 seconds, and it consistently starts that way. Thank you for the recommendation on the MiniVci and we still do have a 32-bit laptop kicking around the house.
  9. Marathon Jon
    Harvard, MA
    Fuse #14 (STOP), 10 amp, in the left side instrument panel fuse compartment under the dash turned out to be blown. Replacing it brought back brake lights and also normal starting action. Still have the traction control light on so I may go searching for another blown fuse or perhaps try the traction control disable procedure to see if that corrects it.
  10. JC91006
    16,674
    8,519
    Disconnect the negative on your 12v battery for10 seconds to reset the car. The lights will go away and see if they come back
  11. Marathon Jon
    Harvard, MA
    I disconnected the negative side for the time you recommended but the traction control light didn't go away. The time was sufficient to reset the clock and trip data, but not long enough to reset the radio presets. Also the GoPoint technologies OBD reader didn't see any codes.
  12. bisco
    51,155
    probably not a prius competent reader.
  13. kkmalu
    kkmalu New Member
    I am having the same problem, I'll go check the fuse but did you find any solution for the traction control light staying on?
  14. kkmalu
    kkmalu New Member
    So I replaced the #14 fuse and it blows up every time i start the car. Any thoughts on whats going on?
  15. mrbigh
    3,686
    699
    Long Island, NY
    And fuse #14 protects witch circuit????????????(n)
