Replaced 12volt battery, but still not running
Discussion in 'Gen 2 Prius Technical Discussion' started by beribets, Dec 8, 2014.
  1. beribets
    beribets New Member
    Aurora, CO
    My 2007 Prius suddenly lost power and all lights on the dash board light up. I had a "problem" error as well. Eventually a message came up stating there was a transmission P lock mechanism problem. Long story short, realized the 12volt was dead and replaced it. However, the car is still not running after replacing the battery. It went once around the block fine, and then the same thing happened with all the lights (check engine, VSC, break system, and !) and P lock mechanism warning. Disconnected the battery for 15 minutes and tried again. No luck. Before having it towed to the shop, was wondering if there is some other DIY trouble shooting I can do. I've read several posts about fuses and bad combo meters. Thanks!
    49,437
    could be you didn't tighten the battery terminals enough, the negative to body should be checked, and you should test the battery, new ones don't mean good ones. if that doesn't do it, go to auto zone and have them pull the dtc's.
  3. beribets
    beribets New Member
    Aurora, CO
    Would you suggest taking it back to where it was purchased to have it checked?
    49,437
    either that, or buy a digital volt meter for ten dollars or so. how did you figure out the old one was bad?
    edthefox5 likes this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Welcome to PC!
    Like Bisco says get a volt meter and measure across the front under hood jump points. Or...Quick test is turn on the headlights. No headlights or really dim the 12 is bad again.
    Whats the deal on the car? Is it a salvage title perhaps? Mileage?
  6. beribets
    beribets New Member
    Aurora, CO
    From under the hood? The battery is located in the trunk. Bought used 3 years ago from Toyota dealership. No problems until now. Mileage is 90,000.
    Lights do come on. The car does actually "turn on" but all warning lights are on and it won't even let you put it in neutral. We took the old battery and it was completely dead. Thought this new one would solve the problem.
  7. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Yes under the hood. These are jump start points. On right side is black plastic fuse box. Take cover off. Little red plastic cover. Flips up. Reveals a little metal L bracket thats bolted down. That L bracket is connected to the 12 positive post on the battery in the hatch. You attach your + jump cable clamp to that L bracket. Use the bolt head right above the box thats bolted to the strut as the - ground clamp connection.
    Its in the owners manual.
    You of course can measure the battery 12 there.
    uart likes this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Hmm...
    I suppose the obvious is that perhaps the original codes and problem wasn't related to your 12 volt battery. Perhaps the transmission P lock mechanism problem is actually a Transmission P Lock mechanism problem?
    The battery could be of been unnecessary or coincidence.
    The first step that you are at now, IS determining that your new battery is good, and installed correctly.
    Then if that checks out? You're back at square one, with "codes" and a problem.
    Guess your best hope is that it was the battery, and again IS the battery.
  9. beribets
    beribets New Member
    Aurora, CO
    Thanks, didn't know that. We've jumped it before, so I know the front technique.
  10. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Ok so you have used these jump points already?
  11. beribets
    beribets New Member
    Aurora, CO
    Yes, just weird that it would be multiple problems occurring simultaneously. Just my luck, eh
  12. beribets
    beribets New Member
    Aurora, CO
    Yeah, I have.
  13. Yakoma
    Yakoma Active Member
    470
    122
    ATL-ish
    Uh oh...I think I know where this is going.
    uart and edthefox5 like this.
  14. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Its not multiple problems. Its usually one that affects all the circuits that are in alarm. Usually its the 12 volt. Car throws all the alarms when that goes bad.
    Its a mystery until the codes are harvested. With those we can tell you pretty close why the car is unhappy.
  15. edthefox5
    10,096
    4,805
    Clearwater, Florida
    LOL......me too....
  16. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Me three...
