Replaced bad cell now car wont start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by doug1810, Jul 9, 2015.
  1. doug1810
    doug1810 New Member
    stockbridge
    Hello
    First post here first off i love these cars. My car started giving me trouble i ran the scan tool and it told me that cell 6 was bad on my battery. I replaced the cell and put the battery back in now the check engine light is on and the problem triangle is on and the car wont start and only shifts into neutral but when i check for codes i get nothing . Any ideas would be great.
  2. JC91006
    16,496
    8,406
    The orange plug on the hv battery.....you have to tilt up, THEN PRESS DOWNWARD to lock it in place. Then try again to start
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Have you made sure that the orange interlock on the end of the HV battery has been engaged properly?
    Many have made the mistake of not engaging the interlock the correct way which is:
    plug it in,
    rotate it 90 degrees upward,
    and then press it straight downward
    which is the opposite of what is shown below (which disengages it).
  4. doug1810
    doug1810 New Member
    stockbridge
    I think it is in corret i have 220 volts across the battery . I will check
  5. doug1810
    doug1810 New Member
    stockbridge
    That was it you guys rock
  6. JC91006
    16,496
    8,406
    You might want to invest in a MiniVCI cable with techstream software. That will allow you to diagnose your car better. The error you had should have thrown a code if you have the right equipment to retrieve it.
  7. doug1810
    doug1810 New Member
    stockbridge
    I will look into one of those. Thanks
