Replaced Batter
Discussion in 'Gen 2 Prius Main Forum' started by Kstew1120, Aug 18, 2014.
  1. Kstew1120
    Kstew1120 New Member
    Perkiomenville, PA
    So my dashboard lights lit up a couple weeks ago. Took it to toyota, and they said it was the battery that one cell was bad. So i bought a cell, pulled the car apart, took the battery out and replaced the cell. it was fairly simple. So i put the battery back in, hooked everything back up but now if I hit the button to start the car, while pressing the break, the light on the button goes orange and the car wont start. If i do not press the brake and I hit the button, it lights up green and just the radio comes on. Anyone have any ideas?
  2. JC91006
    16,482
    8,400
    You probably didn't lock the battery interlock switch (orange master switch). flip it up 90 degrees and then you have to push it DOWNWARD to lock it. You should be able to start the car after that.....you probably would have to press the start button 2 times initially.
    xliderider likes this.
  3. Kstew1120
    Perkiomenville, PA
    That worked! I have been trying everything to figure it out. Thanks!
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    This is the number 1 newbie mistake.
    You are not the first person to make this mistake and you wont be the last.
    The real question is.... how many other things did you miss while putting it back together. :)
    Keep us up to date on how long your fix lasts. Thanks.
  5. joel903
    joel903 Junior Member
    When you popped the new module in, did you balance the battery pack before install or no?
  6. Shakti
    Shakti New Member
    sydney
    this issue you describe of just power light on and orange was happening in my test drive and i couldn't get it to start then green and just radio - but the seller could? driver error or something wrong with the battery? alas the guy selling me the car is a dealer and knows jack shit about how to make em drive...surely it's not that hard?
    This
