Replaced big battery just goes to neutral
Discussion in 'Gen 2 Prius Technical Discussion' started by [email protected], May 2, 2011.
  1. sww@noadt.com
    [email protected] New Member
    Fort Worth
    This is my first attempt at posting so forgive me if not doing right. I took my 2005 Prius to dealer and was told both battery computer and battery CPU were bad (easy $4,000.00 fix). So, I pulled big battery, located bad cell and replaced with simular voltage (7.9 VDC used cell). After re installing, the car will only go to neutral and will not start. Note, before tear down, car would start and run (i drove home from dealer). Befor pulling big battery I could reset trouble lights for short time by removing ground to AUX 12V battery. Now, lights don't change and are always on. Car wil not start or run and will only go in "Park" and "Netral" and "B" does not show on dash like usual. Please help.
    Steve
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    First thing the trouble shooting experts will want to know are the fault code numbers.
    Good luck.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Do you have the traction battery disconnect turned back to the locked position?
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Pressed firmly? It takes some force.
    Tom
  5. sww@noadt.com
    Fort Worth
    i'm not sure what traction battery is, but if it is the hybrid big batttery and your talking about the orange saftey disconnect than the awnser is yes. Any other battery outside of 12V battery, than no. sorry i know enough to be semi-dangerous. please advise
  6. Patrick Wong
    18,200
    6,472
    Assuming that you removed the orange traction battery interlock switch while removing and replacing battery modules: when you reinstall the switch you need to rotate the handle 90 degrees, then slide it to lock in place. The sliding part of the process is often forgotten.
    If that is good, then you'll need to retrieve the current DTC to obtain a clue about what else is wrong with your car.
  7. sww@noadt.com
    Fort Worth
    i think your talking about the big battery with the orange safety disconnect. if so, it was not difficult to latch in position. if it should require a firm press than it may be broken. i did check that it has contnuity.
  8. sww@noadt.com
    Fort Worth
    yes i did slide it and lock into place, i do not know how to retrieve the current DTC (sorry don't know what DTC means) Thanks, please advise
  9. Patrick Wong
    18,200
    6,472
    DTC - diagnostic trouble code
    I suggest that you have your car towed to another Toyota dealer so that the DTC can be read and a diagnosis provided to you.
  10. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    This does sound like a problem with the orange service plug, specifically with the handle not being slid downward, after it completes the 90 degree pivot during plug insertion.
    If not that, then there is a wiring problem inside the battery case.
  11. qbee42
    18,058
    3,074
    Northern Michigan
    Not to be overly critical, but the OP's comments raise several red flags. His lack of familiarity with common terms such as "hybrid battery" and "DTC" suggest he shouldn't be mucking about inside of the hybrid battery module.
    Tom
  12. epoch_time
    epoch_time Active Member
    234
    108
    las vegas
    This does sound like a problem with hv service plug or its fuse.If someone forgets to install the service plug properly then remembers to reinstall the service plug while the prius is in ready mode will cause the the service plugs fuse to blow.There is aproximately 100 amp fuse within the removeable hv battery service plug (orange colored high voltage safety interlock).This fuse cannot handle the surge current to charge capacitors in the inverter with the system turned on and someone inserting the service plug.Normal prius operation energizes a (capacitor) precharge relay in the hv battery pack first then about one second later the main hv relay (within the high voltage battery assembly) is energized eliminating surge current and NOT blowing the service plug fuse.The service plug should be installed with the prius ignition/ready mode turned off.
  13. Flying White Dutchman
    4,374
    313
    big battery? dont now about DTC... and you replaced the "big battery"
    lets call it the hybrid of tractions battery and not the "big battery"
    there are so many connectors you have to take of to takeout and replaces a cell.. check and double check them all
    and readup a liitle before you do anything like this.......
    really dont think you are for real... not reading about the hyrbid battery but replacing cells anyway is not a smart thing or just a fake post.
  14. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    Put the wrenches down before you kill yourself, seriously.
  15. IABoy
    IABoy Junior Member
    36
    Iowa
    Although I have not seen the traction battery, my impression is that it was quite heavy, several connectors to fuss with and not something for your shade tree mechanic to do on a Sunday afternoon. But I could be wrong. ;-)
  16. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Hybrid Components
    It is visible if you remove the rear cargo floor and then the black tray underneath it.
    Andyprius1 likes this.
  17. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I was able to carry my old HV battery from the back of my Prius to my work bench in the shed (about 25 meters) with little difficulty. It is not that heavy, and two people can handle it comfortably. I am 68 years old, but in good physical shape. :D
    The only reason for a "shade tree mechanic" to avoid working on these batteries is the high voltage risk involved. :eek: You have to know what you are doing and be careful.
    JeffD
  18. epoch_time
    234
    108
    las vegas
    Did you remember to connect the hv ecu. The hv ecu is within the hv battery case. If the hv ecu is not connected the can buss will not be terminated with termination resistor. resulting is loss of communication with hv ecu and other ecu's on the computer buss.. If hv ecu is listening to data on the computer buss (functioning prius) You would hear two Relay clicks when turning on the car (ready mode).
  19. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    What is the condition of the 12 VOLT Battery????:cheer2::cheer2:
  20. cooltroy
    cooltroy Junior Member
    Wisconsin
    I forgot to put the orange disconnect switch back in and my 2006 did the same thing, nuetral only.
