Replaced dented 05 hood now won't latch
Discussion in 'Gen 2 Prius Main Forum' started by Shooter, May 2, 2016.
  1. Shooter
    Shooter New Member
    Louisville, KY
    Replacing a hood, easy fix, right? Not for me.
    Okay... the very front and center of my hood, right where the hood latch is, was dented and I drove it like that for more than a year. The dented hood was opened and closed several times over that year, and it closed fine! It would latch up with no problem. I replaced the dented hood with a hood with no dent, from the same make/model Prius. Now... the hood won't latch! DOES ANYONE KNOW WHAT DAMAGE COULD HAVE BEEN DONE TO THE LATCH WHEN THE DENT WAS MADE? WHY DO YOU THINK THE DENTED HOOD LATCHED FINE, AND THE UNDENTED HOOD ISN'T LATCHING?
    Any help would be very much appreciated! Thanks!
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Because the latch was dented with the hood. You're trying to latch an undented hood into a dented latch.
    The way you described it says the dent is in the location of the hood at the latch. It is highly likely that the hood and latch were both dented at the same time - not enough to damage the latching mechanism, but enough to move it out of the correct position. The two dented components work fine, but now you're trying to latch a hood to a latch that's in the wrong place.
    Make sense?
    49,604
    complete. maybe it was thrown out of alignment. these are a tricky fix. first, make sure the seams along the sides of the hood and fenders are even. once everything is tightened down, if it won't latch, try loosening the hood catch, just enough so the catch can move it as you press down on the front of the hood.if it latches, open gently and tighten the fasteners.
  4. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    Post 2 explains well....
    Look to what called the radiator support metal support panel...bet its bent.
    Test your latch, get a helper, pull cable make sure it is functions!
  5. Shooter
    Shooter New Member
    Louisville, KY
    I'll try all of this. All of you... thanks for your feedback
