Replaced driver side front door glass. Auto up doesn't work!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ScottY, Mar 10, 2012.
  1. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Car was broken in last night. Went to a near by auto glass shop to get the glass replaced. After the glass replacement, the window will lower half way after it reached the top using the auto up function (pull up and release). It stays up if you hold the switch up. Any ideas why that is? Seems to me the jam protection is activated, according to the manual.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    You probably need to reset it. The procedure is in the Owner's Manual
  3. Patrick Wong
    18,200
    6,474
    You could try disconnecting the 12V negative battery cable for a few minutes. Then, reset the driver's window auto up feature.
    If you still have a problem, then I suggest you return to the auto glass shop and ask for help, as there may be an installation problem.
