replaced HID bulbs twice and still have porblems
Discussion in 'Gen 2 Prius Main Forum' started by marthaskol, Jan 10, 2011.
  1. marthaskol
    marthaskol New Member
    NY
    I was so proud of myself I replaced the 1st bulb on my 2006 Prius 30 mins, but not so happy when it started to intermittently go on and off again. I bought the bulbs on ebay from a recommendation I think from this forum for 2 for $40. So feeling perhaps the 1st bulb was defective I replaced I replaced the second one in 15 mins. But after a few days of ok, once again it went out intermittently again. So could it be a bad ballast? Is it possible that both bulbs were defective? I'm willing to try again if someone could post a link to the bulbs that worked for them.
    BTW this is an awesome link to changing the bulbs, I didn't even need to disconnect the power cord from the boot...
    in not allowed to post the link (5 times thing) but it's on You tube called "how to change your Prius HID bulb in 10 minutes (part 1)" there's a part 2 as well. All I needed was a multi screwdriver
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Either the bulbs were defective or the glass was contaminated during installation. Did you wear latex or nitrile gloves? By the way, $40 for a pair sounds way too good to be true for d4r (did you use d2r by mistake?). $90+ seems to be the going rate.
  3. marthaskol
    NY
    I did wear gloves, but I was also careful to never touch the glass. Can someone send me a link to a legitimate bulb retailer that they have used. Thanks
  4. marthaskol
    NY
    Is it possible it "the control module" and not the bulbs. I read this on a parts website? Can anyone tell me what the control module is? and can I replace it?
  5. Doc Willie
    1,717
    142
    Out there, somewhere
    I had the same trouble with a pair of HID bulbs. Both of them. I sent them back, and bought the OEM Sylvanias, and the problem went away. The dealer admitted that these cheaper bulbs don't work in the Prius.
