Replaced hybrid battery no start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by binthe920, Jun 8, 2023.
  1. binthe920
    binthe920 Junior Member
    WI USA
    Ok so my 05 has a bad hybrid battery and rather than replace it I bought a 2010 gen 3, well a little less than a year goes by and I have signs of a bad head gasket and now my brake light is on and no cruise control but my hybrid battery is good so I swapped it into the 05 that had no other problems and now the red triangle is on and it won't start but it's showing the hybrid battery is 3/4 full?
    Any suggestions where I should start?
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    Use the appropriate scanner to retrieve those obd2 codes (DTCs), then post them in this thread for additional guidance.
    Did you try power cycling it twice?
    FYI : you're moderated until you've posted 5 times.
    Brian1954 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,432
    5,422
    Pacific Northwest, USA
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    If I understand the OP correctly, he took the "known good" pack out of his Gen3 (that has been in use) and put it into his Gen2 (that had been sitting).
  5. mr_guy_mann
    4,111
    2,011
    NJ-USA
    Step one. Make sure the orange HV fuse holder interlock is fully seated. It's 3 steps. 1) insert the holder, 2) swing the lever in, 3) slide the lever straight down until it clicks.
    If that's ok, then you need a capable scantool to check different systems (such as hybrid control and HV battery) for codes.
    Here's a thread that reviews several scantool apps and devices.
    https://priuschat.com/index.php?posts/3290690
    jerrymildred likes this.
  6. ttou68
    ttou68 Active Member
    351
    211
    My question is..
    Did you swap the battery packs or the complete traction battery itself?
    My understanding is that Gen2, and Gen3 use the same battery packs but not the same control module..
  7. PriusCamper
    13,432
    5,422
    Yep... It's highly unlikely that anyone would use anything but the actual modules from Gen3 when using them to get a Gen2 Prius going again. But if someone didn't understand this level of obvious I sure hope we get to see pictures...
    SFO likes this.
  8. Tombukt2
    Tombukt2 Senior Member
    13,839
    2,514
    Durham NC
    I don't think you can swap the whole case from the Gen 3 into the Gen 2 The battery fan ductwork and all that won't even line up and I don't even think you could plug your plug into the traction batteries computer and all that I think the relay layout is a little different and that sort of thing.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    This is physically impossible. The cases are completely different. You have to transplant the modules.
