Replaced injector now Prius won’t start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by collers9640, Jul 7, 2021.
  1. collers9640
    collers9640 Junior Member
    16
    Charleston Sc
    I replaced my injectors and now I can’t get Prius to start.
    It will try and start but then it quits and the HUD says check hybrid system stop the vehicle in a safe place
    I also put a new 12v battery in but it have 12v when I check it.
    Anyone have any clue what’s wrong
    49,431
    12v may be too low for a new battery. charge it up, and measure the voltage at the jump point under the hood
    Samuel Williams Jr likes this.
  3. PriusCamper
    PriusCamper Senior Member
    11,091
    4,514
    Pacific Northwest, USA
    Any lights on the dash? Error codes? Symptoms prior to you working on it? Seems like the electrical signal that fires the injectors are not properly connected if the problem was caused by you working on it. But that's just a wild guess... And sometimes totally separate problems show up soon as you fix the existing concern.
  4. Samuel Williams Jr
    246
    Dayton NV
    If it started before and now it doesn't? It's most likely something you did? What was the last change? The Battery or the Fuel injectors?
    You to double check your work. Is everything hooked up correctly? And if it is, it's not impossible to get new part's that don't work. It's not the norm but some times crap happens?
    You could also reinstall the old parts or get a OBD II, Dongle and a Phone App and pull the codes to see what's up?
    ralph seifer likes this.
  5. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Check the throttle body connection
  6. Glojazzbent
    Glojazzbent Junior Member
    23
    Kansas City
    Did you ever figure out what happened? My gen 3 is now doing the exact thing after fuel injectors were replaced.
