Replaced JBL head unit, wanted CarPlay
Discussion in 'Gen 3 Prius Audio and Electronics' started by benb, Aug 21, 2015.
  1. benb
    benb New Member
    I replaced my HU with a Pioneer AppRadio4 leaving stock JBL amp in place. Prior to ordering I warmed up to the idea after seeing how easy it was on this thread: New install: JVC GPS replaced JBL HU | PriusChat
    The dash removal really is easy - I just used my fingertips. 10mm socket to undo the 4 bolts securing the HU and a flathead screwdriver to depress the release catch on each of the HU wiring harnesses. Used PAC's products to allow me to keep the JBL amp and speakers, along with the steering wheel controls. You only end up needing to wire together 4 wires and I just used wire nuts I had leftover from previous electrical work on my house.
    The hardest part was probably programming the steering wheel controller (PAC SWI RC). It's sort of like programming the old universal remotes. You press a button on the PAC unit, hold it, press it again, press the steering wheel controls in a specific order, etc.... It wasn't too complicated but you had to do it all in order and in a certain timeframe. I had someone help by reading off the order for me so I could focus on the button mashing. Looking back I might redo it and make the "Mode" button on the steering wheel act as a mute button instead. Who changes the source/mode using that button anyway? Plus now everything you'll want to do will be on one source - the USB connection/CarPlay.
    I ran the mic wire behind the HU, left along the underside of the steering wheel, then up the rubber moulding on the driver side door opening. Popped out at the top left corner of the windshield and then ran it across to just above the rear view mirror. It was really easy to work the mic wire into the moulding and between the ceiling material and the rooftop - almost didn't need any tools, just a screwdriver to gently push the wire into a few tighter spots. Popped out the plastic moulding just behind the sunglasses holder and put the mic there. With the moulding back in place the mic just pops out of the rear left corner, facing the driver.
    Ran the USB and AUX connectors down from the HU, popped them out through the stub just to the left of the cigarette lighter (cubby below the HU/shifter). I put the AUX here because I was sure how to wire up the AUX in the bottom of the center console where the other cigarette light is.
    Here are a few pics of the install and of the firmware update I did later:
    You can see in the pics that I initially installed using the stock mounting brackets but I later reinstalled using the brackets that came with the Scosche faceplate. The Scosche brackets provide better support for the faceplate to keep it stationary whereas the stock brackets allowed the faceplate to move around a bit, which was annoying when you rested your hand on the faceplate while using the HU touchscreen.
    I also have been having some trouble with fader controls. I noticed if I tried to fade to the rear to even out power between front and rear speakers, the power/volume would fluctuate randomly between front and rear speakers. This was really annoying/distracting.
    Not sure why, but there might be a problem with the PAC interface. I've been removing the HU repeatedly, trying to troubleshoot. My most recent attempt has been to bend the contacts of the black 8 pin connector (connects the HU RCA's to the PAC interface). I slightly bent them outward thinking they would make better contact with the internals of the PAC interface. I've also been adjusting output power levels via the HU controls (onscreen) by upping power to the rear speakers (I think this is called Speaker Levels), in combination with fading to the rear (the more standard/familiar fader & balance controls).
    Previously I tried increasing and decreasing the power boost outside the HU controls, as well, using the PAC interface's dip switches. The switches provide 0-7dB boost depending on dip switch setting. I found a 7dB boost seemed most similar to the power level of the stock HU, which means setting the 1, 2, and 3 dip switches to On.
    I had some trouble with the PAC-SWI (remote interface for steering wheel controls) after initial install, too. During one of my reinstalls of the HU while troubleshooting the fader/power fluctuations, I reprogrammed the remote to configure the Mode button on the steering wheel to act as a Mute button instead of a source changer, as mentioned previously/above. Reprogramming the remote was easy, but I noticed the Siri button (which you have to hold down for about 1-2 seconds to activate, btw), and the answer & end call buttons on the steering wheel had stopped working properly. I tried reprogramming the controls 3-4 times with the same results. Ultimately I unplugged the remote from the back of the HU and plugged it back in, and this seems to have fixed it. Must've gotten loose during one of the reinstalls.
    #1 benb, Aug 21, 2015
    DFW, Xterra72, avusblue and 1 other person like this.
  2. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    Where are the photos of your new system?
  3. benb
    benb New Member
    Added some pics and some more info
    52,590
    well done!(y)
    benb likes this.
  5. DFW
    DFW Member
    39
    31
    Dallas
    Nice! I have a pioneer install I'll be tackling shortly.
    Does your car have a backup camera? Any direction on which wire to tap for reverse? I believe I read there is a blue wire in the passenger side kick panel.
    How did you wire the parking brake wires? As directed by Pioneer?
  6. LDB
    LDB Member
    279
    71
    Does this work if you have the basic system to begin with? I think that's what I have. I know I don't have the one marked JBL. Not really sure if there is more than one below that or not.
  7. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    Looks good and much better then the stock unit.
    Thanks for the details.
    benb likes this.
  8. benb
    benb New Member
    I didn't have a backup camera and didn't add one. The post I linked at the beginning has a walk-through of how to do it, though. He talked about wiring all the way back through the hatch-door. My guess is there should be a wire already on the harness for the backup camera because the stock camera wires into the Nav HU (when it factory installed).
    I just grounded the parking brake wires and my HU accepted that as sufficient... no more blocking video.
  9. benb
    benb New Member
    I think you'll have a different setup if you don't have the JBL system. One of the components I used (TATO) is entirely unnecessary if you don't have the JBL system, because the TATO is what communicates with the factory amp that comes standard with the JBL system.
    If you're going to upgrade the non-JBL you might want to consider adding an amp and maybe replacing the speakers, from what I've read.
  10. DFW
    DFW Member
    39
    31
    Dallas
    One would think there'd be a reverse wire! Ya I need to find stock wiring diagram.
    Great, I have it set up to just be grounded.
    Thank you!
