Replaced my AC condenser
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by eluo, Jul 15, 2023.
  1. eluo
    eluo Member
    101
    64
    Commack, NY
    Took the better half of today and got my AC condenser replaced. I was able to remove the condenser without removing the bumper. It cost me $123 in parts and new tools. The tools that already own and used for this were just a socket set and an air compressor.
    My Parts list
    Amazon.com
    INTAKE Manifold Gauge Set, Car AC Gauge Set for R134A, R12 Refrigerants, 3 Way AC Gauges with 5FT Hoses, Adjustable Couplers, Can Tap & Adapters
    $39.99
    Amazon.com
    SCITOO A/C Condenser Compatible with 2004-2009 for Toyota Prius AC3093 3093 TO3030192
    $50.24
    Amazon.com
    Interdynamics INDHYB-2 Ac Oil Charge-Hybrid
    $8.99
    Advance Auto Parts
    R-134a Automotive Refrigerant, 12 oz
    9.77
    Harbor Freight
    PITTSBURGH AUTOMOTIVE Air Vacuum Pump with R134A and R12 Connectors
    13.59
    Stated with removing the plastic cover (not shown) and the bolts under that cover
    Also needed to remove this bracket with two bolts under the bracket
    Remove the hood latch. There are 4 bolts. Two on each side and one on the top, and one on the bottom (out of view in this pic)
    Not shown, there are 2 sets of brackets, 3 bolts, and a screw holding the top of the condenser, the radiator, and the fan shroud together. One set on each side
    Photo of the bottom screws. These screws were tough to remove. Had to do it slowly to not strip the head. I used a very long extension and put a lot of pushing and turning force to unscrew it. It would have been easier if Toyota used bolts instead of Phillips screws
    The condenser removed after disconnecting the lines to it. I snapped off one of the bolts attaching the line to the condenser. It wouldn't come out even with heat applied to it. In the end, I used a replacement bolt that I had lying around. Believe it is a M6-1.0 25mm bolt
    NOTE: If your system is still pressurized with r-134a, do have the refrigerant removed properly at a shop that provides AC service. From what I read, this is a free service.
    Old and new condenser. The old one had a sizeable oil stain from the leak
    Took suction with the Harbor Fright Air Vacuum Pump. It worked fairly well with my large 30Gal compressor
    Once a good seal was confirmed, I pressurized it with the Hybrid Oil and then the R-134a.
    AC is now ice cold. Hope the photos help those looking to take on this task.
    SFO and Leadfoot J. McCoalroller like this.
  2. Leadfoot J. McCoalroller
    7,131
    6,679
    Pennsylvania
    2018 Prius c
    Hopefully they didn't screw around with that condenser.
  3. eluo
    eluo Member
    101
    64
    Commack, NY
    Think I am good with the high-side gauge value. I'm not looking for perfection. With almost 250k miles on the odometer, the cheap fix will do, and this is not my primary vehicle. Will have to see how this new condenser will affect gas mileage.
    Driving without AC in warmer weather, in the past month surprised me with unusually high MPG. I got an average of 52 MPG. I haven't seen that high for years. I always thought it was the worn hybrid battery causing my low MPG.
  4. Leadfoot J. McCoalroller
    7,131
    6,679
    Pennsylvania
    2018 Prius c
    I'm really just curious for tracking purposes, do you have an opportunity to count fins per inch on that SCITOO unit?
  5. eluo
    eluo Member
    101
    64
    Commack, NY
    Sorry, I don't plan to take it apart to get to it. Here is a zoomed-in photo if it helps.
  6. Tombukt2
    Tombukt2 Senior Member
    8,876
    1,549
    Durham NC
    Looks pretty close to me I can't imagine that would be a problem usually just having the condenser whatever kind you should see the crappy condenser's cars used to have was unbelievable big gaping holes in between the fins if you will so don't know but that looks pretty comparable I run a desert cooler radiator and one of my cars that looks almost like this condenser actually it looks more like the radiator in the Prius that you're working on but it's two rows thick. I didn't even see your high side reading but if you're 30 to 36 on the low and the fat tube is cold you're pretty much getting what the compressor is going to give you or if it's getting cold your expansion valve is working for the most part so.
  7. pasadena_commut
    pasadena_commut Senior Member
    1,442
    433
    Southern California
    I think Lech (resident AC guru) had a video on youtube where he railed against cheap condensers. Not saying this one is, but it could be. Saw that video a long time ago, so I might be getting this wrong, but as I recall the problems were condensers which were contaminated in shipping and had to be pumped down for some insanely long period (like a day) to get them clean and dry enough to install, and condensers which looked superficially like the OEM ones but had less cooling capacity. It was some function of the number of tubes and the density of the fins, but I don't recall what exactly. Also I think the Prius is supposed to be charged by weight, not pressure. Unclear from the notes above which method was used.
    Also, the OP implied that the system had already leaked out all the refrigerant. That would allow water vapor in. Water inside is bad. The whole system might need to stay pumped down for a considerable time to get that out.
    Isn't there some sort of dessicant like component (drier) which is also supposed to be changed if the system has been open to the air? I don't see that in the parts list.
  8. Tombukt2
    8,876
    1,549
    Durham NC
    Yeah receiver dryers are good to replace when the system is open how long it's opened also makes a difference but there is that I wouldn't say the Prius is any more susceptible to any of this than any other 134a system My van sat with a broken condenser for longer than I wanted like a month or two I did not replace the receiver dryer even though it was $24 I just didn't have it when I replaced the condenser so I went ahead and gassed up the vehicle been working fine ever since of course it is a sienna van but still very similar to the 134A system in all Toyotas and I don't think any systems generally charged by pressure in the past few decades it's pretty much by weight or volume most of our Toyotas hold like a weird amount 1.3 lb and like he said he can drop that in one load into your system and that's that so can I here pretty much . I have many types of gas here for many types of systems I do a lot of work on mini splits in the like which run 410A.
  9. Leadfoot J. McCoalroller
    7,131
    6,679
    Pennsylvania
    2018 Prius c
    Thank you for sharing this photo (and starting the thread) Good luck & stay cool!
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,191
    5,884
    Columbia, SC
    Never realized Harbor Freight sells a venturi style vacuum pump for AC systems. What level of vacuum was it able to achieve?
    I have a question about your refrigerant charge. The repair manual calls for 450 +- 30 grams for a fresh charge into a vacuumed system.
    12 ounces is only 324 grams. Did the oil charge come with a few ounces of refrigerant to push the oil into the system? Would be perfect to find an oil charge that also has 4 ounces of R134a as the pusher. (Although a vacuumed system doesn't need much pushing)
    Copy and Paste from repair manual:
    2. CHARGE REFRIGERANT (a) Perform vacuum purging using a vacuum pump. (b) Charge refrigerant HFC-134a (R134a). Amount: 450 +-30 g (15.9 +-1.1 oz.)
  11. mr_guy_mann
    mr_guy_mann Senior Member
    3,423
    1,482
    NJ-USA
    Venturi type vacuum pumps don't pull deep enough to properly boil off air and moisture. You can mitigate that somewhat if you can get (most of) the A/C system crazy hot. Force the ICE in maintenance mode with the heater on full hot - recirc.
    So there's some air and moisture left in the system - pressures will be a bit high and there will likely be corrosion forming inside. The OP is apparently fine with that for a "short term" fix.
    Ain't perfect and it's not likely to last for years. But it works "good enough" right now.
  12. mr_guy_mann
    3,423
    1,482
    NJ-USA
    Zoom in on the picture, the fin count looks about the same, but the new unit has fewer tubes across the same width, so overall has a bit less effective area.
  13. Leadfoot J. McCoalroller
    7,131
    6,679
    Pennsylvania
    2018 Prius c
    Yep, that's my observation as well.
  14. eluo
    eluo Member
    101
    64
    Commack, NY
    The condenser came with a new air dryer.
    SFO likes this.
  15. eluo
    eluo Member
    101
    64
    Commack, NY
    Thanks for this info. The oil came with 2 oz of R134a and I added another 12 oz. I'll need to add a bit more.
  16. eluo
    eluo Member
    101
    64
    Commack, NY
    The pic of the gauge shows -27inHg. Using this table, it is around 90% vacuum. What is considered deep enough?
    Right, if this fix lasts through this summer, I will consider it a win. Honestly, I think the hybrid battery will die before this A/C does.
  17. pasadena_commut
    1,442
    433
    Southern California
    See this thread:
    How Prius owners unknowingly kill their electric compressor | PriusChat
    and watch the video in the first post. Here are two other of his videos, one about condensers:
    and another where he discusses gauges, micron measurements for pressure, purging with dry nitrogen and other things (on a Kia BEV, but the Prius system is more like that than the belt driven ICE sort of system):
    Note that he goes down to tens of microns, where 1mmHg is 1000micronsHg, so a much more complete vacuum than the 90% your system achieved.
  18. dolj
    dolj Senior Member
    7,627
    3,848
    Wellington, New Zealand
    -30 in Hg, I believe.
  19. TwoPrii
    TwoPrii New Member
    My Pittsburgh compressor brings it all the way to -30 Hg, just fine.
    The thing I'm seeing now, is maybe my condenser is bad and not the compressor.
    Lost 22.5 oz. of R134a over night yesterday after driving it around all day ice cold with 40-45°F at the vent...
    Thought everything was good (after it held vacuum for an hour, before filling) but, no.‍♂️
    SFO likes this.
  20. dolj
    dolj Senior Member
    7,627
    3,848
    Did you replace the high and low side valves while had it evacuated? If not, it might be a good idea to do that. If they leak, a vacuum test won't pick that up.
    TwoPrii likes this.
