Replaced serpentine belt
Discussion in 'Gen 2 Prius Main Forum' started by George W, Jun 4, 2020.
  1. George W
    George W Senior Member
    911
    514
    San Antonio
    After the Toyota dealership told me that my drive belt had "minor cracks", this is what I was driving with.
    I'm thankful that the dealership brought it to my attention. 10 minute replacement (15 if you count the 5 minutes spent fshing out the dropped Idler pulley).
    bisco and SFO like this.
    52,372
    nicely done (y)
  3. ski.dive
    ski.dive Active Member
    967
    245
    Hutchinson Island,FL. Mt. Snow,VT
    George, how many miles on that serpentine belt?
    edthefox5 likes this.
  4. George W
    911
    514
    San Antonio
    Almost 167,000 miles, Texas climate.
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Look underneath the waterpump for crystallized (or still wet) coolant. If you see any, it's advised to change the pump too. The tech probably didn't get underneath to swap out the belt.
    George W likes this.
  6. Patrick Wong
    18,210
    6,513
    The dried coolant appears as pinkish or whitish powder deposits on the inside of the coolant pump pulley or on the air conditioner compressor below the coolant pump.
    George W and fotomoto like this.
  7. George W
    911
    514
    San Antonio
    Dealership made a few recommendations based on the mileage on the car, but changing the water pump was not one of them.
    I can't say if there is evidence of a leak, but since they pointed out the belt I'm hopeful they checked for other things
  8. George W
    911
    514
    San Antonio
    Thank you for that information. It's going to have to wait until I can get the car up high enough. I used to own those now-recalled Harbor Freight jack stands! :(
  9. sach0325
    sach0325 Junior Member
    The dealership reported this on my prius 4 years ago and also showed me the pink deposit and told me that this could be because of cracked lid and gave me hefty estimate. My other local mechanic however assured me that there is nothing wrong and I should do nothing about it. 4 years since then and its working fine.
    Also, in the same visit, I was told about a few cracks in serpentine belt. I missed that part completely because of the hefty estimate for coolant lid crack scare that he created. I have done no work on my prius and have had no issues in my prius since.
    What are the signs when serpentine belt cracks or breaks? Does it stall the car? or stall the cooling?
  10. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    When the serpentine belt breaks you loose coolant recirculation to and from the ICE. The engine overheats and most likely you warp the head. IMO, this is one of those maintenance items that you want to preemptively manage.
  11. George W
    911
    514
    San Antonio
    On my 2008, I really couldn't see the tiny belt cracks without a bright flashlight, but there were dozens of them . Fortunately the Gen 2 serpentine belt is a 5-minute job, and you're good for another 10 years.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Mine showed cracks at 80,000 miles. You really have to take it off to see the cracks well. Given how tactical that belt is it should be changed by 100,000 miles no matter what it looks like on he car.
    When the belt is off spin the water pump see if its making any noise and also idler pulley. My idler pulley was making some noise so I greased it.
    And if you see deposits the pump is weeping. Maybe not bad but its weeping and will continue till it fails. There easy to see just look down at the front of the engine with a flashlight.
    With a failed pump and no temp gauge in the car you will never know its overheating till the check engine light or over heat icon comes on. Too late the aluminum cylinder head may incur damage. Its a bad system. Pay attention to burning smells unless you have a Scanguage.
    After the belt has been replaced take a look at it after you have driven it for a few days. When new that belt is very stiff and will stretch a bit after use. It may then become loose. Snake your hand in there and see if is loose.
    Also its a good idea to take the plastic cover off the top of the rad as that reveals the rad cap. Open that cap and check the rad level. The over flow tank has really nothing to do with how much coolant is in the car it can show full and the rad could be empty. You do not need to replace the screws when you put the cover back on the hood traps it when its closed. Mine has been loose for 12 years. Makes it very easy to check the rad fast. If you see any spots i would be checking that level very frequently. Coolant level should never change over time if it does you have a leak.
  13. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Compared to some other cars the belt should be pretty lose. Specification for deflection with 10kg or 22lbs of force in the center of long run between idler and crank pulley is 9...12mm or 0.35...0.47" with new or 11...15mm 0.43...0.59" with used belt. But its almost impossible to measure this so you just have to fell it.
