Replaced tranny, now the buttons on the seering wheel aren't working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Miguel Olivares, Jan 22, 2017.
  1. Miguel Olivares
    Miguel Olivares Junior Member
    56
    Oakland
    Replaced the tranny on a 2008.
    I noticed the streering wheel airbag light is on now.
    Will it deploy on me randomely?
    Also, I noticed that my buttons on the wheel aren't working( the temperature buttons, aux audio buttons..)
    I don't mind going under the hood, what do you guys suggest?
    48,934
    might you have pinched a wire with the tranny?
  3. Miguel Olivares
    56
    Oakland
    I don't think so. Everything was working well (without the light) for about 3 days before today. Not only did the light come on today but the buttons don't want to work anymore.
    48,934
    that's usually the clock spring, but i don't see the relationship. how many miles on her?
  5. Miguel Olivares
    56
    Oakland
    210k.
    Whats the clock spring?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    If you dropped the steering rack you have to tie up the steering wheel so it does not free wheel spin because if allowed to do so it will rip the clock spring which is basically the printed circuit board under the steering wheel face. The steering wheel has to be pulled off and clock spring assy replaced.
    Paul Schenck and bisco like this.
  7. bisco
    48,934
    the spiral cable from the steering wheel buttons down the shaft.
  8. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    716
    Boulder Hybids, Boulder, CO
    Clockspring aka Spiral cable is broken behind airbag. When you remove subframe you must secture steering wheel with seatbelt or rope etc so it doesn't turn on its own.
    You can replace clockspring with a Chinese one and it will last about a year. New one from dealer will last 10 years but is almost $300. Anything on Ebay that says it's new Toyota at a price under $200 is counterfeit and will last about a year.
    Wishconsin and bisco like this.
  9. Miguel Olivares
    56
    Oakland
    Thank you, we found one at a junkyard for 70$.
    Well seee if it fixes the issue.
  10. 3prongpaul
    954
    716
    If it doesn't work the junkyard most like broke it during removal. BTDT!
    (they remove the engine/tranny/subframe then the steering wheel is free to rotate far enough to break the clockspring).
    Hopefully they pulled the clockspring BEFORE the subframe.
  11. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
  12. dolj
    dolj Senior Member
    7,478
    3,761
    Wellington, New Zealand
    Yeah, pretty much that's what everyone else said.
    SFO likes this.
