replaced water pump and belt
Discussion in 'Newbie Forum' started by karinfrench, Jun 30, 2011.
  1. karinfrench
    karinfrench New Member
    mcgehee, ar
    Toyota dealer said computer indicated the water pump and belt needed replacing. We decided to do the replacement ourself. Now the light comes on which indicates car is running hot. We did replace the coolant. The 2005 Toyota Prius never ran hot before the replacement, What did we do wrong?
  2. richard schumacher
    7,656
    1,014
    United States
    Easy stuff: incorrect belt tension, you used the wrong coolant, or you didn't get all the air out. See Bentley or other repair manual for belt tension and for bleeding air (it's not as simple as turning the cabin heater on high for a while and adding coolant). If you used the wrong non-Toyota stuff, replace it ASAP.
    If none of that fits, get thee back to a dealer :_>
    RCO likes this.
  3. adamace1
    adamace1 Senior Member
    1,403
    189
    Charlotte, NC
    I'm going with you didn't bleed the air out.
  4. The Critic
    The Critic Resident Critic
    3,133
    2,235
    CA
    Open the bleed valve that is located near the driver side headlight and stick it in a bottle of fresh coolant. The fill up the radiator the best that you can and start the car, put it in service mode, and allow it to idle for 20-30 minutes. I would consult the service manual for the exact bleeding procedure, but that's what I watched the Toyota tech do.
    RCO likes this.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,521
    Southwest Colorado
    ^^ Is that bleeder valve for the inverter or engine circuit ?
  6. The Critic
    3,133
    2,235
    CA
    Engine.
    MB860 ?
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    913
    251
    Surprise, AZ (Phoenix)
    There are plenty of threads here in the Gen II Maintenance forum that outline the exact bleed process, which is required to get the substantial amount of potential air out of the system. Shorting the coolant reservoir pump relay is the simplest when following instructions.
    Also not mentioned, how much coolant did you replace when refilling? I went through about 6 quarts.
    RCO likes this.
  8. andyprius
    andyprius Senior Member
    2,212
    176
    Sacramento, California.
    I couldn't get the bleed valve to stick into a bottle of fresh coolant. What kind of glue works best for this? HELP in SACTO.:eek::(:mad:
  9. The Critic
    3,133
    2,235
    CA
    Sorry, just saw this. use a small rubber hose and stick it into a bottle of coolant. Get a hose that fits tightly enough.
  10. Andyprius1
    Andyprius1 Senior Member
    2,327
    860
    Cool CA
    That’s funny, I don’t even remember working on this car.
  11. Prodigyplace
    Prodigyplace Senior Member
    11,698
    11,284
    Central Virginia
    That means you are getting old and are no longer a Newbie. :D
    RCO and Andyprius1 like this.
  12. lunacyworks
    lunacyworks Member
    97
    34
    SF Bay Area
    Looks like you forgot your login/password and had to create a new account like me :).
    Prodigyplace likes this.
Loading...
