Replacement front door speakers with tweeters?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Dummy, Dec 19, 2019.
  1. Dummy
    Dummy Member
    105
    Colorado
    2005 Prius JBL audio blown front door speaker. I bought a set of cheap pioneer speakers that have tweeters. I then watched some videos on how to replace the speakers. One of the videos said that you should only use a speaker that doesn’t have a tweeter. Is this correct? If so, can I just clip the wire to the tweeters or should I definitely return them for some woofer-only speakers? Or will it be ok leaving the tweeters functional?
    kenoarto likes this.
