Replacement KEY Needed
Discussion in 'Gen 3 Prius Main Forum' started by mgpp123, Jul 2, 2010.
  1. mgpp123
    mgpp123 New Member
    27
    nj
    Hi guys,I accidently lost one of the keys to my 2010 Prius,Toyota wants $300 for a replacement.Does any one out there know any alternatives to getting another key for less?Any help would be welcome.Also if any one can tell me the emails or contact info for Toyota(usa) corporate offices id would appreciate that as well.Thanks in advance for any help.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Your best bet is to go through Toyota in spite of the cost. The car has to be programmed to accept the new key with the SKS system. You will also want them to delete the lost key so that it cannot be used again without your knowledge.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
  4. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I'm on my second 2010 Prius - I had kept one of the keys from my previous one, and purchased one online (Ebay). When I bought my car, as part of the deal, they programmed the others (you can have a total of four keys).
    Programming keys is a major pain - they spent 1 hour+ the first time trying to figure it out. When I brought it in for the tire change (5K miles) - they were finally able to do it.
    It appears (thanks to the Tech forum) used keys get 'locked' after xxx uses. To unlock, Toyota has a special secure software 'tool'.
    If it were me, I would get two (or three) keys ($50/each) on Ebay, and find a dealer to program them all for the same price - it really shouldn't take the dealer any more time to do 2-3 as it would be 1.
    You would then need a key blank - I didn't bother yet (figured *if* the battery dies, I'll call AAA or Toyota assist to unlock). I think the dealer wanted like $80 for each cut blank - of course, those are also available on Ebay...
    EDIT: Key blanks are $10 on EBay (locksmith can cut them), and used smartkeys are $50
  5. RRxing
    RRxing Senior Member
    2,559
    1,833
    NEPA
    Note: A total of seven (7) keys can be registered.
  6. rrolff
    1,610
    246
    So Cal
    Hrmmm - thought from a previous post in Tech that there are only 4 slots available (using Techstream) - can you verify this - I have only read Rachaelseven mention 4 keys (she has the programming tool) - and my dealer explicitly mention I had as many keys as were possible (4).
    I guess from a software sense, it may make sense (3 bits instead of 2) ?????????????
  7. RRxing
    2,559
    1,833
    NEPA
    In New Car Features/Vehicle Interior/Theft Deterrent-Keyless Entry/Smart Key System/Details:
    4. FUNCTION
    (a) Entry Function
    (1) The entry function consists of the following functions:
    (See Attached, under Key Code Registration)
    Unless it's a typo when it was translated...
  8. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    Go to ebay. people are selling keys for $50 or less. Then take it to your dealer to have it programmed.
  9. maomao
    maomao New Member
    93
    DC
    This may not be directly related to this thread. But I have been wondering if I lost my key on the road (dropped it in the lake, etc.), can AAA or any emergency service help me so that I can drive it home?
  10. Colonel Ronson
    443
    33
    Tucson, AZ
    Only way to start the car again is to use another key fob programmed to the car. Without that, you'll have to tow the car. If you have the small little silver plate with the key code still, the dealer can make a new replacement key on the spot. If you don't have the key code, a whole new set will have to be cut and programmed.
  11. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Cant you hold the key next to the start button and start it that way? It has a transponder built in right? I remember reading about it for those that needs to disable the SKS.
  12. tumbleweed
    4,067
    692
    Eastern Oregon
    Yes, it's in the Owner's manual on page 542. I haven't tried it but others on here have and apparently it works OK. It should work if you have a dead key fob battery also.
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    The replacement key mentioned in this post is only the mechanical key. With it you can get inside the car, but not start it.
    Tom
  14. Colonel Ronson
    443
    33
    Tucson, AZ
    To start the car just hold your fob next to the power button.
  15. jeancazort
    jeancazort New Member
    Little Rock
    The number for Toyota Headquarters is 800-331-4331.
    I found my options for replacing a key to a 2011 model
    were to shell out close to $400 to a local dealer or go
    with one key. By the way, prices at local dealerships differed
    widely, so it's helpful to get some quotes.
  16. BrianPB
    BrianPB Member
    114
    36
    Sylmar, CA
    I just lost the metal door key itself and I was quoted 147 for that. I asked how much it would be to get a fob too and he said 250 for the fob and another 100 to program it for a total of 497! I was shocked! 300 seems more reasonable... Dealers are con artists!
  17. Maggie261
    Maggie261 New Member
    Illinois
    Hi Rrolff....I don't know what to look for on ebay. We got one key with our used Prius at the dealer but we need another. I like your idea of buying the keys on Ebay but I don't know what number it is that people are putting on their ads on ebay. Also, will a dealer program 3 extra keys without charging a ton for each one?
  18. kredfish00
    kredfish00 Junior Member
    New Orleans, LA
    I bought a used key fob on eBay for $77 that was unlocked so it was ready to be programmed. It was from an outfit named keylessentryremote. I took the replacement fob along with the original and the car itself to a local locksmith. They have the machine that plugs into the car and basically registers the code of the replacement fob with the car so the car can be operated by the remote. It cost $55 to program the fob and $45 to cut the key blank which came with the replacement fob. It was the least expensive way I could figure out how to do it!
    G2/07 likes this.
  19. Mendel Leisk
    42,115
    A preemptive ploy: attach a small luggage tag to the key, with your phone number.
    Good idea to tape the number on your locking lug nut socket too.
